My operating system is not found and windows repair dont fix computer.im using a rocvery disk for start up repair please help.
  • 57 Answers
As A WINDOWS XP AND BOOOT UP TO FORMAT IT AND BEFORE YOU DO THAT PLEASE BACK YOUR PC
Posted on Sep 06, 2010
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Note that on your Dual Boot system there now should be only one operating system listed.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
g) At the DOS prompt type the following three commands
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
These messages are the result of the radical changes made by removing the other drive.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
Reboot the computer.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
Operating system not found
This is because the windows startup files are damaged / deleted. Please reboot your computer by inserting the windows 98 bootable disk into CD/DVD drive and selecting the option as "R" repair.
In short you will be fixing the master boot record (MBR) for the operating system.
Thanks
Aug 31, 2011 | Microsoft Windows 98 for PC
My dell dimension 2400 is not taking me to a log in screen due (0x00190203, 0x8237B670, 0xc0000102, 0x00000000.i turn the computer on and i click f2.i try changing around the setting because when i restart...
In the Bios of the computer the F2 section that you are talking about what do you see under primary boot device?
You can always use a bootable operating system cd / dvd to boot your computer and reinstall the operating system.
It is possible that the HDD that you have on the desktop is corrupt but if you see the xp screen it is possible that the OS files are corrupt. you can use the recovery CD to fix the problem
Also try tapping F8 when the computer starts and choose Safe mode
if the computer starts then try to run the check disk command - chkdsk /r (for repair option)
The best chance you have to fix your computer is a bootable Operating system CD
Aug 18, 2011 | Computers & Internet
When you turn on the lap top it says operating system not found. I put recovery disk 1/3 in and it loads windows files. Then a screen pops up and says windows recovery center or repair windows. For more...
Do not press on F8. What you need to do is to do a start up repair. Select the option to repair the operating system. Then it will load some files. JUst wait for it to complete the loading process or the repair. It will tell if the repair is successful or not. If it doesn't fix the problem, then, you need to install the operating system to your computer. But, remember that operating system re-installation will return your computer to scratch. It will erase everything including the files and programs that you have added in your computer. But, if you don't have anything to lose then do the operating system reisntallation.
Here's a guide on how to reinstall windows vista:
http://www.blackviper.com/Articles/OS/InstallVista/installvista1.htm
Mar 22, 2011 | Sony Computers & Internet
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
Hi there. The thing that caused the shutdown is a software conflict. Go to the windows advanced option by pressing F8 key when you see the Dell Screen upon restart of the computer. Choose "Disable automatic Restart in system error" and press enter. That should fix your problem.
^_^
May 18, 2010 | Dell Inspiron Mini 10 Netbook
I have boot mgr is missing could you help and tell me what i can do to get my pc working again thanks steve
Hello,there are a number of possible causes for "BOOTMGR is missing" error message.The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drives, an outdated BIOS, and damaged or loose cables.First we are going to try the start up repair.You will need your windows installation disk or recovery disk.Put it on your cd rom,restart and watch for a Press any key to boot from CD or DVD...Press a key to force the computer to boot from dvd.Once it finished loading files Choose the Language to install, Time and currency format, and Keyboard or input method that you'd like to use in Windows Vista.Click on the Repair your computer link on the bottom-left of the Install Windows window.This link will begin the Windows Vista System Recovery Options.Wait a minute to search for your hard drives.
Choose the Windows Vista installation that you'd like to perform the Startup Repair on.
The Startup Repair tool will now search for problems with important Windows Vista files and try to repair them.Your computer may or may not restart several times during this repair process. Do not boot from the Windows Vista DVD on any restart
Click the Finish button once you see the Restart your computer to complete the repairs window to restart your PC and start Windows Vista normally.
Now your done and is supposed to work normally.Let me know if is fixed.Good luck
Feb 05, 2010 | ASUS Computers & Internet
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Sound card
Dear Loreerupe,
This sounds like a corrupted software file. Please use your installation disk and reinstall the sound driver file. This will overwrite the corrupted files and upon the machine rebooting you will have gained sound operation again.
Unfortunately you dont state the model/maker/windows operating system and cannot help any further with instructions/manuals/driver files.
I hope you can fix this,
Regards
Please dont forget to rate this solution if you found it usefull.
Apr 04, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
