Question about Craftsman Air Filter 33021 2 pk for Lawn Mower
I have a Sears (Craftsman) mower model # 944.368300. When I prime it, and attempt to start it, it runs for approximately 5 seconds and then dies. If I hold the primer button in, the mower keeps running. Any suggestions as to what is wron and more importantly, how do I fi it? Thanks
    President:
  • Craftsman Master
  • 1,545 Answers
Try removing the brass bolt that holds the float bowl to the carb on and cleaning it thoroughly. This bolt is the main jet for the carb and can become clogged with varnish or debris esp. if no inline filter is used or gas is allowed to evaporate in the carb. There will be small holes on the bottom and the sides where there are no threads. If no other problems, this should cure the 5 second run.
Please vote on this solution.
Posted on Sep 05, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
Starts when primed but dies...
check your gas cap, try running it without your gas cap on and see if that helps if so id either replace it or drill a really small hole in the top as modern engines the fuel is gravity fed into the carb
Jul 13, 2009 | Craftsman Garden
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Engine cranks, runs for approximately 30 seconds
you nee too take the carb apart and clean it!!!!!!!!!!!!!!
Apr 01, 2009 | Craftsman Garden
Craftsman Air Filter 33021 2 pk for Lawn Mower Logo
453 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
