Question about Garden
I can't keep the machine running under load. Motor cuts-off after I engage revolving core mechanism. I don't have manual. The machine is a rental.
    Problem Solver:
  • 5 Answers
Did you inadvertently trip the saftey mechanism on the front of the saw, on many saws it is a black bar just in front of the handle. disengages saw when it kicks back.Push it forward until it clicks.
Posted on Sep 05, 2010
Powermatic 201 Planer will not start.
I would have to guess the motor has gone to lunch, pull it and test it.
Jan 24, 2017 | Washing Machines
Tip
Manual Door Unlocking of Maytag Neptune Front Load Washers
Maytag Neptune Front-Load Washers are equipped with emergency access cord that can be used to unlock the door when the door lock mechanism fails to unlock it after a wash load is done. The emergency access cord is located under the top cover and can be accessed through the dispenser bezel. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off to access the emergency access cord. Carefully pull the emergency access cord steadily then open the washer door.
The pulling of the emergency access cord overrides the wax motor and the sliding gear is pulled from right to left away from engagement with the rotating gear. It allows the rotating gear to release the wire loop of the door.
The failure of the door lock mechanism to unlock the door is due to a failed wax motor in the extended position. This requires the wax motor to be replaced. Access to the door lock mechanism for the wax motor replacement requires the removal of the front panel and lifting the top cover. Click here for the detailed front panel and top cover removal procedure.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
17.5 briggs motor back fired 1 time and now when i engage blades the motor boggs down
The engine is timed internally and externally. Sometimes when it backfires the external timing key where the flywheel and crankshaft join will be damaged enought to put the engine out of time. The engine may run but when put under a load such as cutting grass it will fail. This is about a 30 minute repair and about $2.00 in parts.
Jul 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I crank mower , blades engage when I don't have them engaged!
The belt engaging mechanism is remaining partially engaged. Check the deck for debris and clean it off really good. Retry. If still occuring you may need to remove the deck to see if there is still debris there or to check for corrosion. With the deck removed, if all the debris is cleaned up and with and you can manually move the tensioning mechanism and see what the hang up is, it might just take a shot of wd40 and moving it by hand a few times to clear it up. If it is a rust thing then you are going to want to keep it lubricated and cleaned to maintain free operation. You should not have to remove the deck every time to lube it, you should be able to get the lube sprayed into there by reaching under once you learn just where your deck needs it.
If really helpful, please rate.
Jul 14, 2011 | Yard Machines Garden
Error code sd I tried canceling, starting over, rinse and spin, unplugging it oh and sparks when I plug it back in at the outlet Help
Suds Detection
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify:
Excessive detergent usage.
Basket cannot engage during drain step.
Mechanical friction on drive mechanism, not allowing basket to engage.It sounds like there is something causing a lot of friction and when you plug it in it has a load on the motor and you will get sparks.
Jun 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
All lights flash says sd
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: Excessive detergent usage. Basket cannot engage during drain step. Mechanical friction on drive mechanism, not allowing basket to engage.
Sep 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine will not reset after overloading it whenever it goes to revolve it trips the fuse
Hi, this is quite a bad problem, what is happening is when the motor tries to engage it's drawing too much current and blows the breaker. Most likely you have a bad motor?
www.serviceforce.co.uk/pdfs/U20460.pdf
http://www.zanussi.user-manuals.com/zanussi-c-2.html?page=59&sort=5d
In any event you will need a service manual to troubleshoot and repair. Above are your manuals sites. one free the other pay for.
Jun 22, 2010 | Zanussi FLA1201W Front Load Washer
As soon as i turn it on, the needle starts moving up and down even though i don;t have my foot on the pedal at all.
as you turn on the motor starts running. but when you press pedal there is a clutch that engages. probably the clutch keeps engaged. clutch needs to be set to engage on pressing pedal only.
Nov 06, 2009 | Singer Sewing Machines
LA5558XSN0 Washer ExLarge Rinse Cycle doesn't engage
sounds like adrain line issue, your creatring a syphoning effect . id assume thedrain line is either real low, perhaps running across thefloor or is screwed tightly to a longer hose ejecting through a wall with a full dry well
Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
