Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon ip 5200
All cartridges have been replaced with original canon products but once i print a photo there appear lines and the black in comes off when rubbed with my finger
  • Addinall May 12, 2008
    I did run cartridge cleaning & are using photo paper but still end up with this problem.
    Problem Solver:
  • 16 Answers
Did you run cartridge cleaning service from your computer after replacing the cartridges? If not, run cleaning once. If the nozzle check is not clear, there another option for deep cleaning, but i think it will take a lot of ink. Do it for best results. This will work. Are you using photo paper for Photo printing? if so give some time to dry the ink on paper.
Posted on May 12, 2008
Canon mg5200 only prints photos
I have an MP540 and it says..."The PIXMA MP540 runs on five ink cartridges, with a photo black as well as a pigmented black for text printing" so it sounds like pigmented is for text and dye for pics. So maybe your default settings are showing high quality, photo or the paper type is causing the printer to select high quality...just a thought!
Parts Of BMW.
May 30, 2012 | Canon Large Black Pixma Mg 5200 Compatible...
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
How do i align my printhead on canon iP1200
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. alignprintcartridgesa.jpg alignmentpanther.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
Apr 20, 2011 | Canon PIXMA iP1200 Photo Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Jul 12, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Black and white photo printing
Paste the address below in your browser.You might find some vital information there.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238
Jul 09, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon s520 printing is skipping
try to clean with tissue paper and see the nozzel of catridge is dust free bye
Sep 24, 2007 | Canon S520 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
69 people viewed this question
old marine
old marine
