Question about Panasonic Lumix DMC-TZ3 Digital Camera
My camera take a picture but it doesn´t appear, all black
  • Panasonic Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Oct 29, 2010
I took 850 pictures but T I can see in the camera only 180. Do you know what is happening?
I think you will have to reformat your memory card.
To do this:
  1. Copy all the pictures from the camera onto your computer.
  2. With the camera on, and the memory card inserted, press the menu button.
  3. Highlight "Setup"
  4. Go to "Format"
  5. Select "Yes"
After this is complete, if it still doesn't work, your memory card is defective and you must buy a new one.
May 04, 2011 | Samsung Cameras
I connected the machine to the computer but it doesn´t appears anything. How do I transfer the pictures to my computer? I´ve done this several times and it worked before
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 01, 2011 | Canon PowerShot A550 Digital Camera
My camera´s flash doesn´t work :/ and it says E:91:01 what does that mean? can I fix it? or my camera is useless
The E:91:XX error code appearing on the Camera screen is due to an Internal Hardware malfunction.
The E:91:01 error code may be due to the issue with the flash unit in the Camera. This can be resolved by checking or replacing the Flash unit.
Before that try the normal troubleshooting steps like power resetting and factory resetting. If the issue persists, it would be better to get the unit serviced at the Sony Authorized service center.
Aug 07, 2010 | Sony Cameras
Problem with SD card, Canon Ixus 100 IS
Could be the camera isn't seeing/reading the card properly.
I'd check the contacts on the card, and in the camera are clean, free of grease & dust.
Rather than do anything drastic, Have a look at the Canon website and or contact them, Details below.
http://www.canon.co.uk/Support/index.asp
Feb 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
N86 camera issue
Here are the steps.
  • go to the camera application while the main camera lens is closed. (front camera will automatically be used)
  • Once camera application is up,open the camera lens. (application will switch to main camera)
  • go to video mode (you cant access image mode settings at it will crash the application)
  • go to the settings of the video mode and choose to reset the camera settings.
  • That should fix it
Feb 24, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
I can´t take the photos out of my camera, it says that camera can´t copy the photo to folder.Some photos copy to my folder, but another photos don´t.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Oct 04, 2009 | Nikon COOLPIX L18 Digital Camera
Olymous fe-180 6.0 megapixel
what size XD card have you in it?
Dec 16, 2007 | Olympus FE-180 Digital Camera
Date doesn`t appear on the photo in computer
Download the userguide from the following link and please refer page 74 & 75 http://esupport.sony.com/perl/model-documents.pl?mdl=DSCW50 Good Luck
Mar 30, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
400 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
