Question about ASUS Eee 4G Notebook
Why my eePCnotebook won't charge?and when it is turn on it immidiately shuts itself?
  • 734 Answers
Hi There,
The source of your problem is the DC Power Jack that your charger plugs into or it is the charger. So, the least expensive way to troubleshoot this yourself is to first get a new charger and that may just solve the whole problem.
If it's the DC Power Jack, that plug in device is soldered to your motherboard inside and it has lossed, broken or the electrical conduits inside it have failed. The cheapest way to deal with that is...
1. Find a local laptop guy who does these repairs often and don't pay more than $100 or,
2. Go online to eBay and in the search window type in "Laptop DC Power Jack Repair". A great many will appear and you can even narrow down the search to find a few who do Eee PCs. The cost there should not be more than $100 and can sometimes be around $80 flat fee.
TIP! If you use an eBay vendor, check their approval rating and only use one who charges a flat fee with a "no repair is no charge" clause.
Best of luck to you!
Posted on Sep 04, 2010
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
Jan 30, 2013 | Westinghouse Televison & Video
My truck won't even turn over. I can jump it and it runs but when shut off it won't startagain
if it turns off as soon as you take of the jumper cables the problem is the charging system. it could be the alternator or relay or a fuse. and after that you need to charge the battery.
Aug 05, 2012 | 2005 Nissan Frontier
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
THE CAR DISPLAYES ANTI-LOCK BRAKE LIGHT THEN SHUTS OFF IMMIDIATELY AFTER 91 FLEETWOOD CADILLAC , BROUGHAM
I am assuming this is while you are driving the vehicle? The light should come on and turn off at start up, as the ABS computer runs a self check. If the issue presents itself while driving, it is likely a wheel speed sensor that is starting to fail. If the computer looses the signal it will turn on the dash light, when it sees a signal again it will turn the light off. Could be a broken wire between the chassis and wheel speed sensor or a bad sensor. If you can, check the ABS codes, they should be stored.
Jan 19, 2010 | 1991 Cadillac Fleetwood
OLYMPUS FE360U BATTERY DOES TURN ON
the LCD screen is malfunctioning
Repair it with the help of a professional immidiately to prevent further malfunction
Jun 30, 2009 | Olympus FE-360 Digital Camera
ASUS Eee 4G Notebook Logo
195 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
