Question about Refrigerators
The fidge inside is freezing big ice blocks along the back of the fridge
  • bazza p May 12, 2008
    this is the same problem i have but i cannot get the temp control switch for it mine is a wirlpool WRN 33N WB6.
    GOOD LUCK WITH YOUR PROBLEM
    BARRY
  • 868 Answers
Check the evaporator heater
Posted on May 12, 2008
Our LG LFC25960ST fridges ice maker jams up. It wont stop making ice then the whole thing freezes up and jams until it is overfull with ice and completely frozen inside.
SOUNDS LIKE UR ICE MAKER HEAT UNIT IS BAD ID THE ICE IN SMALL PC'S OR ONE BIG BLOCK? IF SO CHECK THE WATER INLET VALVE ALSO
May 20, 2015 | LG Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Food in crisper drawers freezing
HI. UMMM I WOULD DEFROST ALL FIRST.24/48 HOURS.AND TRY.MIGHT BE PARTIALY BLOCKED WITH ICE IMPAIRING CIRCULATION.GOOD LUCK.ALI
Jul 05, 2012 | GE (GTS16BBS) Top Freezer Refrigerator
What is best way to defrost hotpoint future rf175b
The model number you gave is not valid. To defrost a fridge you have two options.
Is this a manual defrost? If so boil pot of water and set on rack inside the freezer. You will have to remove big chunks of ice.
Auto defrost fridges. Option 1- Unplug fridge open doors and leave for 24-48 hrs. A bit messy with this so have towels around fridge to soak up water.Option 2- Unplug fridge remove access panel on back wall inside freezer. Take hair dryer and melt all the ice inside on the coils. If you have an ice block you have a problem replace bi metal/efrost thermistat. Heater and/or defrost timer may also be out.
If you have an Ice block on auto defrost models always change the bi metal because they get warped usually inside and ruin them. Test heat with continuity tester and defrost timer by manually advanceing just before shutdown time and letting run through cycle. Should stay in defrost between 8 and 30 minutes.
If you need further assistance or have any questions please comment me back.
Jul 27, 2011 | Refrigerators
HOOVER CLASS A FROSTFREE FREEZE HNMF 2805A L-80 FREEZER IS WORKING BUT FRIDGE INSIDE IS COVERED WITH SHEET OF ICE AND BLOCK OF ICE AT BACK FOOD AND LIQUIDS ARE FREEZING HAVE ALREADY TRIED TURNING DOWN...
I had same problem. Needed a new thermostat. Lasted about 18 months, then needed to replace fridge. Ice build up is between the inside and outside layers of the fridge as well. May just be more economical to replace. Cheers
Oct 26, 2010 | Hoover HCA331FFK
Bosch Fridge Freezer KGN39V00/GB noise
Yes, it may be the fan. it might be rubbing against wires or the back panel. if thats the case you can fix it by adjusting the fan so it wont touch the wires or borders of the panel. if you see that the fan is instead rubbing ice ( if there is a ice build-up behind the panel and its against the fan) then the problem is more serious. you may need to replace the bi-metal,possible the timer, resistence and you may have the drain outlet block with food, ice,etc. good luck .
Mar 06, 2010 | Bosch Freezers
I have a bosch frost free fidge freezer. I have noticed that there is a layer of ice under the bottom of the bottom drawer in the freezer. What is causing it? Thanks
defrost drain is blocked probably with ice
remove back panel inside freezer and drain is at bottom. melt of any ice with a hairdryer and follow up with hot water till water flows away freely. needs patience
Sep 07, 2008 | Bosch Refrigerators
Fidge is icing up inside on the rear
Defrost problem, advance into defrost to see if heater comes. If it does replaced timer, if it doesnt you will need to check heater and defrost thermostat.
Jan 07, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
