Question about Samsung CLX-6210FX Laser Printer
Hello, I have a samsung clx 6200 and am getting streaking on my page mostly in photos. is there something i need to clean to fix this problem?
angelus316
  • 41 Answers
SOURCE: My Samsung CLX-3160FN prints yellow streaks....
try the transfer belt/roller
Posted on May 22, 2009
graysand
  • 558 Answers
SOURCE: I get a line of color across the page, a streak.
you might want to look for the scanner lens wipe it with a soft cloth and try again.
Good Luck
Posted on Aug 26, 2009
  • 406 Answers
SOURCE: I hve vertical streaks on the left side of the
This is the problem of black developer in the imaging unit.
Please visit Authorised service center and they will change for you.
Posted on Nov 02, 2009
  • 406 Answers
SOURCE: I have a Samsung CLX-316N multi function colour
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Posted on Dec 09, 2010
  • 86 Answers
SOURCE: my samsung clx-2160 prints with vertical streaks,
Hi there.The problem is not in the toner cartridge.The fussing roller has been damaged and need replacing.You can see the fuser roller by opening the back cover of the printer.Look for two roller.The fuseing roller should be gray or red.Look at it to see if it`s damaged!
Posted on Jan 15, 2011
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
My samsung clx 3160fn prints with a faded streak in the center of the paper
There is some-thing that is dirty that is making contact with the paper.
My guess is a roller or a little metal guide wheel or the like.
Clean it with tissue paper.
Use the already printed page to line up to see where about the source of the line is comming from.
Till next time!
damnor01
Apr 14, 2011 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
Printing is not uniform across the page. It is heavier at each end
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Dec 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN Vertical lines when printing black
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
Jan 14, 2009 | Samsung CLX 3160fn All-In-One Printer
My Samsung CLX-3160FN prints with the left side of the page being very light, while the right side appears normal.
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then they also needs to be cleaned.
Nov 22, 2008 | Samsung CLX 3160fn All-In-One Printer
Streak
either the cartridges are to the end of its life so please get it replaced .or there is dust in the printer so please get it serviced to avoid the problem further.
Sep 24, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-6210FX Laser Printer Logo
249 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
