Question about RIM BlackBerry 7100t
Phone keeps turning on and off (had gotten multiple errors)
I dropped my 7100t (i know my own fault) and now when i try to power it on it goes either to an error message or it'll make it to the main screen then turn off.
The error messages i get vary from TCU exception reset, abort exception reset, block error 6 reset, system error 500, device error *insert number here*, etc. etc.
If i get lucky enough it will go to the main screen it will always verify the security settings and will stay on if i dont touch any buttons. if i do, it freezes gives off a red light on the led indicator and reset itself. i tried hard resets and using the application loader on the device manager on my computer to fix this but nothing has worked so far.
Any help would be greatly appreciated. Thank you!
My blackberry 7100t was dropped and now the problem is its screen keeps on fading off and colours keep on changing again and again..the screen comes nack to normal if the screen backlight is switched off for around 5 min..it will work normally for sometime may be for ten fifteen min and the problem starts again..suggest some solution for this..and also if u could advice me from where i could get a new battery for the same phone..
contact:
madhur@priest.com
Posted on Jul 16, 2008
When the camera is turned on, the lens goes in and out about 3 times and then the screen displays "Turn the power off and on again". Of course, when I follow these instructions it does the same...
This sounds to me like a lens problem and your camera would need to be serviced. If you're in the East Coast or New York City area give us a call and we'll see what we can do for you. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Sony Cybershot DSCW350 Digital Camera
Sony cybershot dsc-w290 after a recent dropping of the camera when we turned it back on we get this message "turn the power off and on again" same thing happens each time.
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Jun 16, 2011 | Cameras
Error blackberry 7100t
Cause:
Some of the boot up file has got corrupted
Resolution:
Re-install the handset software using Desktop Manager
Jun 09, 2009 | RIM BlackBerry Pearl 8100
Blue screen on main display
Hi. this reoccurring error is due to programing and hardware failure. you will need to remove the battery for 5 minute. if the error continues after you re insert the battery, this will confirm this fault in the hardware. your phone will require repair in this case.
May 22, 2009 | Nokia 6085 Cellular Phone
Sony Trinitron KV-2726R Goes out after a while
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 15, 2017 | Televison & Video
Blackberry 7100t
i just got a 7100t and the battery won't charge. i bought it used, so i don't have a manual. my computer says it does not recognize the device. Is there some type of hardward i need to download before it will work? thanks
May 29, 2008 | RIM BlackBerry 7100G Smartphone
Problem with, HP Officejet 4315, serial no: CN74DG1113. The screen message on printer states cartridge error. The cartridge has been changed twice. Reinstalled cartridge many times, same message appears....
Asalam u alaikum Naveed
as u r getting the cartridge error the first thing to be checked is the expiration date on the cartridges, then take a moist cloth and clean the copper contacts on the cartridge keep the printer powered on and unplug the power cable from the back of the printer and clean the contacts on the printer as well connect the power cable and put the cartridges back.
If the issue still persists then unplug the power cable again
Press and hold # and 6 on the printer while keeping these tow buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on. it ll perform a semiful reset on the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on .
If the issue still persists call HP CARE they ll replace the printer.
Good luck
May 25, 2008 | Office Equipment & Supplies
RCA H100A
drop it about 2ft on hard surface if it does not work try other way
Feb 27, 2008 | RCA H100 MP3 Player
RIM BlackBerry 7100t Logo
148 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
