Question about Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200 dvr
Says no disc whene i try to record or play
I have a cyberhome 1200 dvr ...will not come on, no time dislay, replaced battery in remote. disc door will not open...HELP!!!!
When i put a disk in it reads NO DISK on the display.Does the same no matter how many times i put any disk back in.
  • 1 more comment
  • CyberUMW Jun 02, 2008
    Every DVD I put into the CyberHome DVR 1600 does the same thing: the No Disk message appears. Ejecting and closing 12 to 24 times eventually gets it to load properly - and then all is fine.
    Using a lens cleaning disk is no help because the No Disk problem keeps it from running.
  • Zygmunt Saluk
    Zygmunt Saluk Jun 09, 2008
    nothing works no time display nothing internal fuse ok
    internal battery ok remote battery ok
  • dondd Aug 11, 2008
    Same problem...getting a "no disc" message. I've removed the cover and exposed the laser and cleaned it with a Q tip and alcohol. No help. What I notice is that upon loading a disc, it doesn't spin up, so there's no data to tell the unit there's a disc in place.
  • 25 Answers
Try a dvd lens cleaner.
Posted on May 12, 2008
2 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: cyberhome 1200 dvr
First the Dvr 1200 has hard ware failure in it the tray eject unit and the display is failed ........................................it can fix in local service center.............................
Second your New DVR 1600 check the format of the dvd is it compactiable with format of the player and if face the same problem get it replaced as this is new player manual opening could lead no warranty on the player , it better to get it replaced ..
Posted on May 30, 2008
Cyberhome dvr 1200 doesnt read disc
its lazer is either burned out or too dirty to read the information on the disc try putting a lazer head cleaner through it
Apr 20, 2010 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200 dvr
May 30, 2008 | Cyberhome DVR 1600 DVD Recorder
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1200 broken!!!
sounds like the power supply---open and check the power supply for bulged caps--replace those
Jun 18, 2008 | Cyberhome DVR 1600 DVD Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Cyberhome 1200 dvr
Try cleaning the lens first with a q-tip and some rubbing alcohol. However it's most likely the power supply has failed. Look at the board where the power cord connects to and look for any capacitors that have domed tops. Replacing the two 10V 2200uF caps with 35V 2200uFs worked for mine. I moved the two large diodes over (they had extra solder pads) to get them to fit nicely. I'd also recommend replacing the 220V 0.1uF capacitor with a slighly higher rated one if you can source it. I didn't but I don't trust that one, it has a slight audible whine even after the replacement of the other two caps.
Feb 05, 2008 | Cyberhome DVD Recorder - DVR1600
My is a Cyberhome is a DVR 1200 DVD player
Try unplugging the unit from its power supply. Wait a few moments and then plug it back in. I have the same unit and that is what I have had to do. I am afraid that we have purchased junk. This machine "works" some of the time. It usually functions well as a player but fails on numerous occasions as a recorder.
Dec 03, 2007 | Cyberhome DVR 1600 DVD Recorder
Dvr 1200 will not play
After you have recorded you must "FINALIZE" the disk in order to play it in other DVD players or CPU. Press EDIT scroll down to Finalize Disc then OK
Nov 25, 2007 | Cyberhome DVD Recorder - DVR1600
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
347 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
