Question about Aiptek A-HD 720P Flash Media Camcorder
Aiptek A-HD 720P... quicktime only plays sound
The .MOV movies recorded on the Aiptek A-HD 720P do not play on Quicktime,.... only the audio..... Help ....... !!!!!
So when you are installing the software and you install "total media extreme"(if its an option). later in the installation it will ask you to install 1 of 3 things. The first one says digital theatre. Install that only. Then next time you turn your camcorder on and are loading video to your computer, right click on the file name of the video you want and click "open with" and then "arcsof digital theatre" and it will open the video and play it with hopefully both audio and video....Good Luck.
Posted on Feb 22, 2009
You might need to upgrade your quicktime
Posted on Oct 26, 2008
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Tip
MXF to Quicktime Mov Converter - Convert mxf file to Quicktime mov video on Mac...
MXF to Quicktime Mov Converter Mac, why do you need to convert mxf file to mov? How to convert mxf file to Quicktime mov on Mac with the Mac MXF file to Mov Converter so that you can watch your mxf video on mac by QuickTime?
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple QuickTime. So convert mxf file to Quicktime mov video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
Apple QuickTime movie is stored in the format of Apple QuickTime (.mov, .qt) which is a file format for storing and playing back movies with sound. Though developed and supported primarily by Apple Computer, the format of Apple QuickTime isn't limited to Macintosh operating systems. Apple QuickTime is also commonly used in Windows systems, and other types of computing platforms. In Windows, QuickTime movies usually appear with the .mov filename extension.
Mxf file to Mov Converter Mac is the best partner for you to convert mxf files to mov on mac, just need several simple steps, you can convert mxf file to QuickTime mov video and then preview mxf file by QuickTime. Do you need the best mxf to mov converter for Mac? Just choose this powerful Mac MXF file to QuickTime Mov Converter, enjoy yourself.
http://www.4yousoft.com/how-to/convert-mxf-file-to-quicktime-mov-on-mac.htm
on Aug 04, 2010 | Computers & Internet
The .mov 720p videos made by the Canon sx20si can't be watched
If the files are not big, you can try http://www.zamzar.com/ and convert them to .Avi for playback over the net. Otherwise, try the Rad Videos Tools (Free of Charge), but this requires a working QuickTime install, and can be found here ...
http://www.radgametools.com/bnkdown.htm
Dec 27, 2009 | Canon PowerShot SX20 IS Digital Camera
Trouble playing MPEG 4 file in quicktime
try donwloading a different player like k-pack codec its free go here http://www.free-codecs.com/download/K_Lite_Mega_Codec_Pack.htm
May 09, 2009 | Computers & Internet
Aiptek a-hd 720p flash media files won't capture on Adobe Premiere Elements 3.0.2
I believe it is the format,the easiest thing to do would be convert it but with what? I reccomend quicktime PRO it's around $20 and will not only play the vid, but convert it without loss of quality.
Oct 22, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Burning videos to a dvd
This may be due to the fact that the Aiptek A-HD records to a quicktime format. There is a copy of quicktime in the disk that came with the camcorder. Now I don't know if this is quicktime Pro or not (I work on a mac, so quicktime is already installed, but the comps at my school are vista based) but if you don't have quicktime pro (you can check by right clicking on a video in quictime and if some of the options are unusable because they say "pro" next to them, you don't have quicktime PRO. It's $20 for quicktime pro, and it's very well worth the money. You can change format without losing quality, and so much more! Also WMM is not very HD compatible, you should put it in DVD format :) Hope this helped- (youtube user) animation508
Aug 19, 2008 | Aiptek A-HD 720P Flash Media Camcorder
I can't get my Window's Vista to reconize my Aiptek 720 Hd Camcarder. Why??
You need quicktime, because the Aiptek 720p records to .mov (quicktime) format. If you still have the CD that the camcorder came with, the software is on it. If not, go to google, and search for quicktime free version download. Although I recommend the pro version, due to the fact that it allows conversion of files. It's about $20. Hope this helped-
animation508 (youtube username)
Jul 14, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Sound doesn't transfer from camera into computer
It most likely IS the .mov file. I recommend buying quicktime pro, $20,  which will allow you to convert the file, or if you get the free version of quicktime, and the video and audio play fine with it, You can use a screen recorder and turn off the "record external Mic" mode, and turn ON "Record Computer Audio" Once you're done converting (or recording) You can go ahead and edit, Hoped this helped- sincerely: animation508 (youtub username)
Jun 18, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Trying to save to movie clips to laptop
This camcorder saves files as .mov files. These are readable with Quicktime (from Apple) Quicktime Pro ($30) will convert to AVI format but with some loss of quality. I am sure there are other programs, possibly freeware to do the same thing, but I can't reccomend anything.
Apr 12, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Aiptek - Video and sound is out of sync
Are you recording in High Def? When I tried that on mine the same thing happened. That definitely has to be played back on Hi Def TV and the computer probably isn't capable of handling that. Switch to DVD mode, or Web cam mode and you won't have a problem.
Dec 03, 2007 | Aiptek A-HD 720P Flash Media Camcorder
Aiptek A-HD 720P Flash Media Camcorder Logo
276 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
