Question about Pioneer AVIC-F700BT Car GPS Receiver
My avic 700BT will not turn on...it powers up to the start screen (some times) then every thing goes black and nothing works???? Please help!!!
I have the same radio and the same issue has any one figured it out ........
Posted on Nov 22, 2011
Posted on Sep 05, 2011
I have the avic 700bt series and as of latley when i go to turn it on it will turn on and then turn off 20 sec later or it wont even turn on at all. A lot of the time it will turn on or off randomly and i have checked the wires and grounds.. plz help
Posted on Mar 18, 2011
Pioneer avic 700bt
The Avic F700BT does not have a DVD player, it only has a CD player. If you want DVD capabilities you need the Avic F900BT.
Mar 31, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
I have a pioneer avic-f900bt and it keep turning off. it powers up for a couple of seconds and then it shuts off what could that be please help me.
I appear to have the same issue with mine. I purchased mine from Audio Itch in Tampa, Fl in December of 2008 and had them install it with an amp and speakers. Worked fine for almost exactly a year. Upon starting up my car, it powered up and gave the system powering up notice, then went blank. Rebooting with the small restart pinhole button sometimes works, but most of the time it will start powering up again, then shut off????
Mar 07, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
PSU hangs the system: can't turn on; turns of in 30 min
either the power supply needs replaced or there is a short on the board...
pull the mb and guts of the system out of the chassis
connect the power supply with one cpu and one stick of memory for testing.. no add-in cards installed
then test the power capabilities..
if the system works out of the chassis.. ( alot of work to do ...understood )then there is short to the chassis of the from the motherboard
i really think the power supply is the issue though
Sep 29, 2009 | Computers & Internet
AVIC-F700BT won't work after dealer did some work on it
Have you tried updating the firmware? A new version is available from the Pioneer website. You will need a blank, formatted SD card. Unzip the files from the Pioneer download and copy to the SD card. With the key out of the ignition put the SD card into the unit. Put the key in the ignition and turn to position I to turn on the F700BT. The update takes around 10-15 minutes. Ensure that no unnecessary electrical accessories are on in order to save battery life.
If that fails you may wish to check out www.avic411.com.
Jul 10, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Broken pioneer premier avic f90bt
hope this helps...http://avic411.com/forum/viewtopic.php?f=33&t=25424&p=173322&hilit=+black+screen#p173322
Jun 30, 2009 | Pioneer AVIC-F90BT GPS Receiver
Pioneer Avic-F700BT worked perfectly fine for 7 months but....
Hello!
My pos just did this today after I got in a hot car (had windows up for security).
Symptoms:
Briefly displayed the PIONEER default splash screen, LED lighting was the default ... light/bright pink (to match pioneer?).
Then screen goes black, then backlight gets fully dimmed and LED dims to darks white (R,01G,01B01)
Wouldn't really respond to anything... but plays CD in background.
I had a brainstorm while sitting in my car at ACC (ignition) and reading the lame online TS guide.
I turned my car to ON and put the gear shift in REVERSE.
The screen flashed to the password, and flashed black again....
Some how the system stablelized after some time and I resurrected it*.
* After tinkering I found ALL settings except the NAV data/settings had been lost.
In addition I believe corruption has occured in the memory holding the voice data. TTS... that phone thing voice command wont display when i press down on the Multi-nav? dial. Also system crashes when I try to access language settings. Sometimes a Windows CE error message bled thru reporting a fatal application error. Illegal operation request...
Hope this helps. I think my POS is going back to cartoys before my 30days is up.
Pity
Jun 05, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Windows starts to set up then screen goes black and
9 times out of 10, the finger points to the power supply.
Replace it and try again - I reckon you'll be good to go!
Apr 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Flatron l1717s blank screen
Common cause of this is the VGA or DVI connectors not screwed on tight on either the back of the PC or the back of the monitor.
Also try removing power by unplugging for 30 seconds, sometimes that will reset things.
Feb 16, 2008 | LG L1717S-BN 17" LCD Monitor
Avic x1r fault
It's the flexible PCB ribbon that goes to the screen. According to Pioneer, they no longer offer replacement pieces.
Dec 05, 2007 | Pioneer AVIC-N2 Car DVD Player
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Pioneer AVIC-F700BT Car GPS Receiver Logo
1,156 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
