Question about Hotpoint Ovens
We have a hiph point oven and i was changing the bulb inside but i forgot to unplug the oven. I heard it pop and the oven would not come on anymore. The stove tops works but the power to the oven or the lights on top will not come on either. Did i blow a fuse or is there a way i can reset it? i don't have the model # but we bought it about two years ago
    New Friend:
  • 34 Answers
You must have blown a fuse, where are they?, here's a long shot: usually they are in the dash board where you have access to them by lifting the cover over the dash,
Or they can also be under the stove, remove the pots and pan drawer and look at the back wall.
Jacques,
Posted on Sep 04, 2010
I've got a built in double oven, SCD302TS with no light in the lower oven. Replaced bulbs with known good but no dice. Top oven lights when lower oven is opened, so it's not the switch. Any ideas?
i just looked up your model number and when you change a halogen bulb you should buy the bulb and socket or lamp assy. part 14-38-437 and that's the part the bulb plugs into you can't get it anymore,i just was on sears and repair clinic and it's unavailable
Nov 06, 2017 | Ovens
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
I was cooking dinner. Was using Kenmore oven on Broil and heard a loud pop. Everything went dead. Is my oven dead? Can it be fixed and how much would it cost? Would it be better to buy a new oven?
they dont make em like they used to anymore.. be looking under the top for a burnt wire somewhere..if the burners still work its ok if they dont. check your fusebox.. see if a fuse blew..
Mar 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
My wife was heating the oven to 400 degrees for baking. As she walked away, she heard a pop sound. The control panel was off. I checked the breaker and it was OK. While I was in the oven, I checked the...
it sounds like something shorted in the clock assy. check the elements to see if they are damaged,sometimes they blow apart and also take out the clock assy.when you change the bulb anywhere you want to make sure the power is off to it,shut off the light switch and when you open the door hold in the door switch or just unplug it or kill the breaker,you can try to get the rest of the bulb out with a pair of needlenose plyers,next time send the model number and i can look up your machine to help you find out how much the part is and part number.
May 14, 2011 | Frigidaire 30 in. Electric Gallery Pro...
How to change bulb on newworld g90 vision cooker
To change the bulb is quite easy, the glass lens screws off, give it a good soak and clean whist popping out to buy a new bulb, otherwise you won't notice the difference. Note the bulb is a special oven bulb, if yoo can't read the old bulbs rating it's probabily a 25W 230/240V rated for 300deg C - try Wilko's around £2.50
Sep 18, 2010 | New World G90m Gas Double Oven
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Inside oven lights won't work.
Hey,
I went to the appliance store where I purchased the oven, and they called a Dacor representative. A flat end tool was given to me to pop out the plastic covers. There are no screws to fasten the covers, so you have to use this tool - which was not put in my kit at the time. Be careful when doing this, because the plastic cover can break. You replace the bulbs by pulling out and pushing in the socket. There is no turning the bulb. Handle the bulb with a paper towel, because the oil from your hands will take life from the bulb. Very important that the oven's breaker is off before this is done. Luckily, I had a very kind clerk helping me, and she even gave me the bulbs free of charge.
I like your website, and I will use it again in the future.
Feb 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Ovens Logo
140 people viewed this question
Top Hotpoint Ovens Experts
ashburton
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
