Question about ASUS P5P800-MX Motherboard
Turns on but thats all
Hello.
i got a p5p800-mx the other day and plugged it in. it utrns on but thats it.
help please
  • 3 more comments
  • Anonymous May 12, 2008
    my Tedelex plasma model EC- PD1000 just got blank when I was watching TV with my family. I took to TV repair shop , I was told it is not fixable. I was give the list of burned stuffs. Power board, XDASH BOARD and XU DASH BOARD. I was told that there is no Tedelex representative in Namibia. Please help. lebby@iway.na
  • kipper125 May 12, 2008
    no quite. the screen works fine. when i turn the computer on, no signal comes through the vga
    other details: i plugged in a western digital wd1200 (sata) drive and itspins up. if i unplug i, the computer doesn't start. if i install an ide drive, it doesn't spin up. i tried adding another graphics card but it made no difference. i have got 2 515 kingston ram sticks in it and they both work fine because i tested them. and i have a 300 watt power supply.
    when i turn the computer on, nothing else happens except the sata drive spins. even when i only have the drive plugged in, the ram in and the cpu in.
  • Anonymous Dec 30, 2008
    P5P800-MX the same problem, When I turn it ON nothing happens. just de fans turn on, I see lights burning nothing else. I hear the HDD spinning. I unplugged al peripherials only the MOBO, CPU and powersuply, nothing happens. please help!!
    gr
    Max
    Genius:
  • 1,019 Answers
It appears that your problems, Are the initial setting up of your Motherboard. If you Have The Boards Installation CD.
I,d suggest using it. Set-up the computer with bare minimum devices. 1 x hard-drive. 1 x CD Rom. 1 x Monitor.
If you are getting no Display, it,s possible That Your Motherboards graphics chip drivers are not installed.
If you do not have the driver CD, go to the ASUS site, and download all drivers for this Board.
Settings for the SATA Or IDE configuration, are within the Systems Bios Settings.
Finally, ensure that all the settings are correct for your configuration requirements.
Mike @ Compurepair.
Posted on May 12, 2008
Motherboar driver 841
http://support.asus.com/Download.aspx?SLanguage=en&m=P5P800-MX
May 03, 2013 | ASUS P5P800-MX Motherboard
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Which graphics card would be supported by P5P800-MX motherboard?
Too bad your ASUS P5P800-MX specs. does not have any Graphic Card Slots ie AGP or PCIEX. slot.
Your Graphic Cards options are rather limited, you only use the PCI Graphic card type.
Hope it helps.
Apr 28, 2011 | Computers & Internet
Asus P5P800-MX Motherboard supported Processors
If you are looking for the supported processors.. please take a look at the link below
http://www.superwarehouse.com/Asus_P5P800-MX_Motherboard/P5P800-MX/pf/728092
Aug 16, 2009 | ASUS P5P800-MX Motherboard
How to connect front audio panel in a asus p5p800-mx mobo
Hello there.
I understand that you need to connect the front audio panel to the motherboard.
The user manual which came with your Computer will have the steps and illustrations to connect the front audio panel to the motherboard. If you have the manual that came with your Computer please refer to that.
If you could not find the manual you can download that from ASUS website. The below link will direct you to the download manual page.
Click here to download
or
Copy-paste the below link in the address bar of a web browser.
http://support.asus.com/download/download_item.aspx?product=1&model=P5P800-MX
Thank you
Good bye and Take care
Raviteja
Feb 21, 2009 | ASUS P5P800-MX (90MBL0T0G0UAYGZ)...
Processor
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
make sure your cpu has a 800mhz fsb
Dec 22, 2008 | ASUS P5P800-MX Motherboard
Driver of p5p800-mx
hi try this
http://www.driverstock.com/ASUS-P5P800-MX-driver-download/6-9-10168/index.html
Aug 29, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Asus
Need Audio driver for Asus K8S-MX mother board
Jul 26, 2008 | ASUS K8S-MX Motherboard
ASUS P5P800-MX Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
