Try opening up the LEFT side of the ADF. Takes a little finger muscle to do this. Clean the rollers with a clean cloth, and check to see that there is nothing lodged in the mechanism (staples, loose paper bits, mother-in-laws, etc). Also, there is a limit to how many sheets the ADF can take at once - I haven't maxed mine out, so I don't know how many sheets is the maximum allowed.
Hope this helps
SOURCE: Canon ImageClass D760: With sheets to be copied
Try to clean the tires with WD 40, apply a small amount only in a white cloth (cotton fabric), and clean it
SOURCE: Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
