Question about Microsoft Windows 98 for PC
Scandisk pen drive driver
My pendrive is scan disk. i want the driver for it. please tell me asap.
  • Anonymous May 22, 2008
    sandisk driver
  • djurusik Feb 10, 2009
    I have a Sandisk that i need a driver for for my Windows 98 computer so I can copy files and photos to transfer to my new computer
I want 98 pendrive driver for all
Posted on Oct 23, 2008
Used by windows 98 pc please downlode driver of 98
Posted on Aug 21, 2008
    President:
  • 1,257 Answers
First let me know which operating system you are using ,so that i can help you further ........
---------------------------------------------------------------------------------------------Thanks and Regard
dilipbagdi
Technical Associate
Posted on May 17, 2008
Scandisk pendrive is not detect
Check Your pen drive in your friend's pc that it works or not because there is a chance that some driver is missing on your pc.
if same thing happens also on friend's pc your pen drive is faulty and by no means you may get it working because pen drives cannot be repaired . Try a replacement if it is under warranty.
Thanks.
Feb 28, 2011 | Computers & Internet
I was just format my scandisk titanium cruser 2 gb pendrive and after 1 day my pc can not detected my pen drive i was trying to install u3 launcher but my pen drive is not detected to install. pls help me...
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Please insert a disk into drive E: my pen drive
hey plz help me out of my pendrive...
1)whenever i insert pendrive the error cums please insert disk it gets detect but it shows this error and i cant open
2)second problem m facing dat my pendrive is not showing me in disk management just ican change a drive letter
3)i did everything by changing drive letter also...
plzz sumone can help me out...
Aug 21, 2010 | Generic Memory USB 2.0 128MB Black Pen...
Sir my scandisk pen drive can not open on any pc
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pendrive detect for win98
windows 98 does not install usb pens automaticaly you need cd for that. which comes when you buy the flash. or download driver from scandisk.com
Mar 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Pen drive not opening on xp
Appreciate the direct "Ask Me".
Initially, pls try the pendrive in another computer to verify that it is a pendrive's issue and not the PC's USB port.
A couple of things you can try:
  • use a file recovery utility/program (such as GetDataBack) if there are important files in the pendrive;
  • go to the pendrive's manufacturer's website and download (if available) recovery software;
  • use a utility program to scan/clean/fix, something similar to ScanDisk or Norton Disk Doctor.
If the above will not work:
  • format the pendrive and try to an un-format/recovery software;
  • format the pendrive using HP USB FlashDrive Utility; adn try again a file recovery software.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 19, 2008 | Computers & Internet
To use moserbare 1gb pen drive
sarwesh,
to use USB mass storage in Windows 98 you need to install drivers for your mass device. So,
  1. Findout if any CD/DVD shipped with your pendrive. Install driver from that to your Windows 98 PC, then you can use it.
  2. If you don't have any setup disk from manufacturer, there might be drivers and software prestored in your pen drive. Use this pendrive to any other PC with XP/Vista. Burn these files to any CD/DVD and then make install these drivers to your Windows 98 PC, after that you can use your pen drive on your Windows 98 PC.
  3. If you are not able to do step 2, then goto manufacturer's site select your model no. and download driver and install.
If still you didn't found. Tell me your pendrive manufacturer and model no. I will try to give you link.
Thanks
Iqbal
Apr 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen Drive Not Opening
this happen because of two resion
there must be a vires effective
or your or your pendrive have a bad plz try to format your pendrive.in comand dos mode and you can also run a chk dsk command
or scandisk
Feb 28, 2008 | Computers & Internet
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Microsoft Windows 98 for PC Logo
675 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
