Question about Kenmore Refrigerators
I have a Kenmore refrigerator model number 25358685894. The defrost does not working. I have changed the heating element once about a year ago and thought it might be the same issue again. I notice when I turn the timer dial to defrost the compressor shuts down but the heat element is not warming at all. I checked the voltage on the two wires that clip into the element and it reads 77volts. Should it be reading 110 or is 77 correct? What would be my next test to perform?
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
Kenmore side by side Model 106.59562990, is frosting in freezer side,
If you are getting frost that is gasket issue your refrigerator is made by whirlpool you can find one using your model number
Nov 06, 2013 | Kenmore Refrigerators
Freezer getting tomuch ice,fridge doesnot gets cold
The problem you describe is very frequent. The fridge is getting the coldness from the freezer through a chant and the force of a motor fan Motor evaporator
Number: 173301 Substitution: 5300158289 part no. 26. So the build up of ice in the freezer is blocking the air pass thought and get the fridge cold. Also it may block the fan motor blades from rotating.
So the first you need to check is the heating element on the evaporator in the freezer department. This element might have burn out (and now is open circuit) and even f the defrost timer give instruction for start heating up the element is bad so the defrost is not performed. You just need to replace the heating element. Heater
Number: 178425-01Substitution:5317842502
Is the part no 1 in the diagram in this link.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-2538648024/0582/0160000/00040500/00003?blt=06&prst=&shdMod=
If the heating element then the defrost timer is bad and does not give any instruction to the heater so you need to replace the defrost timer Defrost timer
Number: 174820 Substitution: 215846602 part no 40 in the following link
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-2538648024/0582/0160000/00040500/00002?blt=06&prst=&shdMod=
As you can see in above links and the one below you can find all the parts of your fridge which the diagrams can help you find them.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-2538648024/0582/0160000?searchedModel=64802&blt=
Nov 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
My refrigerator stopped working and will not come back on. It is a Jenn-Air Side by side purchased 4 years ago.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Microwave Ovens
The refrigerator side has stopped cooling.
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 18, 2009 | Refrigerators
My frigidaire side by side is not cooling well anymore...10 years
Aug 17, 2009 | Frigidaire FRS26ZSG
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
FREEZER KEEPS WORKING NOT REFRIG
Yes, the defrost thermistat turns the element of when temps reach about 50 degrees F. The adaptive defrost tell the fridge to go into defrost. When the ice melts the defrost thermistat turns the element off.Whe can check the defrost thermistat if you like.
Your refrigerator has a adaptive defrost board inside the fresh food compartment hiding behind the control panel. That would be the first thing to consider that may be bad. But you also said you manually defrosted the refrigerator and it began doing this again about a month later. Take the model number and enter it in the search feature for model at it will take you to a page so we can look at the same refrigerator and work together to fins the answer. Below is a link click on that to look over your model. The adaptive defrost part number is 61005988
Let me know when you are ready, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
It is also possible the defrost thermostat is defective or a problem with a defrost element. Did you cange both element whith new defrost thermistat? Part number 61006199
May 11, 2009 | Maytag MZD2766GES Side by Side...
Kenmore side by side refridgerator ice around freezer fan
I am looking up your refrigerator to see the right parts. Sounds like the defrost cycle is not happening. look for a defrost or adaptive defrost board. Check your model number again because I am not able to find the number listed. I will continue to check for the correct refrigerator and if you find a simple defost timer turn it clockwise slowly until you feel and hear a click. If you do and you may hear the elements heat up inside the freezer. If that happens just put a new defrost timer and you should be set. Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
Refrigerators Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
