Question about Breville CT20 Retro Classic 2-Slice Toaster
Breville classique toaster
Toaster will not toast although it does depress and holds for usual time. Does not heat up
    New Friend:
    Problem Solver:
  • 6 Answers
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
Breville classique toaster - toaster-wont-stay-down-1h1xuof4er41rm4qkikzo3jl-2-0.jpg
Posted on Jan 23, 2015
  • 87 Answers
Burned out element . replace unit.
Posted on Jul 12, 2008
My breville toaster model BTA840XL won't drop the bread in for toasting
If your power-socket is off, it won't. (I've done it several times, foolishly cursing the toaster). :rolleyes:
Otherwise unplug from wall, remove covers, check by pressing base down with a pen etc. On most auto-eject toasters, a powerful electromagnetic solenoid (electric magnet) holds the base (slice carriage) down while cool and warming up. When preset temperature is reached, solenoid is de-energized, releasing its magnetic hold on the base, allowing springs to pop bread up.
If you (or friend) has a tester and expertise, check solenoid (small coil) for resistance. If OK, (not open circuit), problem is in control circuitry.
Dec 18, 2016 | Breville Kitchen Appliances - Others
How do I fix my toaster?
Probably a burnt out element. See this video if you want to fix it
Jul 22, 2015 | Breville Kitchen Appliances - Others
Left side does not drop toast down, elements work.
I had to take my toaster outside and clean out the sidees of each slot. There was debris baked on and it had the wire frame stuck. Once I cleaned, scraped and emptied out the junk, the toaster works fine.
Jan 25, 2011 | Breville BTA840XL 4-Slice Toaster
Toaster will not stay down when you put toast in
I found that the problem was caused by crumbs getting onto the electro-magnets that hold the toaster down, and onto the contacts that supply power to the magnets ant elements. Removing the cover was the trickiest part - my machine had screws with triangular holes in the heads that a normal screwdriver would not fit. I found, however, that these are the same screws as used in McDonalds Happy Meal toys, and you can get special drivers on ebay or from amazon for them. After that it was just a question of cleaning all the contact points inside the toaster (make sure the toaster is UNPLUGGED!!). 15 minute job.
Oct 04, 2010 | Breville CT75XL 4-Slice Toaster
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
Lever will not stay down unless you hold it down to cook the toast
The latching relay is either faulty, or the timer module has faulted. That usually happens when the Toaster has a "Fault" on it. I suspect that the Timer has faulted. Toasters really aren't usually fixed, but if you have a handy appliance repair shop why not get a quote, for a repair, or replacement.
Mar 25, 2010 | Breville CT75XL 4-Slice Toaster
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Can you turn off the annoying beep when toast is
Hate to tell you this, but from the looks of their manuals on the similar Australian model, then no.
"When the toasting cycle is complete, the toaster will ‘beep’ to indicate that the toast is ready. No need to wait while the toast cooks."
Dec 03, 2009 | Breville CT75XL 4-Slice Toaster
Breville CT20 Retro Classic 2-Slice Toaster Logo
606 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
