Question about Sylvania 6413TE 13" TV
I want to play my plug-n-play on my Sylvania 13" TV, but i can't find the right input. How do i set it up for audio and video?
  • Sylvania Master
  • 5,127 Answers
Which plug-n-play unit do you have? The ones I know use RCA A/V ports (called composite video by some). The TV you listed has front A/V ports according to the specs. If this is true for you, you need (if it wasn't included) either an A/V cable with 3 RCA plugs on each end or two cables (one video (one plug on each end) and one audio (2 plugs on each end). The plugs are usually colored yellow for video and white and red for audio. Just match the colors on both the cable and the TV and the plug-n-play.
Otherwise you will need some sort of a converter (component video to RF or component video to composite video). Both are available at many stores (like Radio Shack) and online. Component video has 3 plugs (Y, Pb, Pr - red, green and blue is a common designation) on each end just for the video. You also need the A/V audio cable mentioned above.
The final thing you need to do is change the source to the input in question. I'm not sure on this TV if it has a source or input button on the remote. On some older TVs you switch sources by changing the channel down from 2 or up from the last available channel. (This assumes you haven't hidden any channels that didn't have a signal previously.) Some universal remotes don't have a compatible source button.
I hope this helps.
Posted on Sep 04, 2010
  • Cindy Wells Sep 04, 2010
    I got distracted for a few minutes. Some TVs have the front inputs behind a protective panel. Press in the middle to get it to come loose from the catch and then pull down.
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
How do I set up my tv to play from my dvd player?
All you need to connect is as follows:
1. use a stereo - two RCA- connection cord to connect from the DVD- L/R line/audio outputs to be plugged into the TV's line / Aux In connection which is the sound of the left and right channels.
2. Now connect one RCA cord to link the Video out from the DVD to the video IN of the TV.
Now switch on TV , insert your DVD and select the INPUT Connected, be it LIne 1 or LIne2 to see the picture.
Jul 23, 2011 | Sylvania Televison & Video
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Hi, I am having trouble connecting my Nintendo Wii to my Onkyo TX-SR507
Take the adapter cable from the Wii that plugs into the back of the Wii and converts the output(audio/video) into RCA style pin plugs, you will have: RED=right channel audio, plug it into any of the red audio INPUT on your Onkyo, then you will have WHITE=left channel audio, plug it into the other white INPUT jack next to the red plug on the Onkyo, then you will have YELLOW= video(picture) that will go directly to the yellow video INPUT on the back or side INPUTS of your TV.
Then when you want to play the Wii, set the input mode on the Onkyo to the inputs that you connected the red and white plugs into, then change the input on your TV to which ever the input is labeled on your TV in which you plugged the yellow plug into, you now will have sound comming from your Onkyo and the Wii up on the TV screen ready to play. Good luck!
Jan 27, 2010 | Onkyo Tx-sr507 A/V Receiver
I have a mocel 6427TFY sylania tv and can not get a DVD player to play though it I set tv on channel 3 and connected to video and audio connections
you would have to select the video/audio source(that you connected the DVD to) on the tv by pressing the input or video button on remote or tv front panel.
Oct 31, 2009 | Sylvania 6427TE 27" TV
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Sylvania 6413TE 13" TV Logo
250 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
