Question about Car Audio & Video
Car stereo code input protocol for blaupunkt 520 car audio system
Could u please tell me the correct input sequence of my car stereo code? i have changed the battery in my car and cant find the stereo manual. please help
  • 6 more comments
  • addo225 May 25, 2008
    how do you prepare the 520 to recieve security code.have tried all manner of button pushing sequence to activate input of coding.display indicates a steady c o d e .
  • snehal_h_dar Jul 14, 2008
    How can I reset the blaupunkt 520 ? is there any master reset as I tried to put the code as explained but always it comes out 9 safe, than 8 safe after each trial and now not able to have 10 - - - - ?
  • klose1408 Aug 09, 2008
    I have receently changed the battery in my Holden Astra and do not have the code for the radio (Blaupunkt 520).Car bought second hand, previous owner cannot remember code!
    Any suggestions for unlocking?
  • FATGTO Sep 18, 2008
    hello i need the code to my astra blaupunkt 520
    BP8391y3475513
  • trivedi19 Dec 17, 2008
    i have the same problem with my honda accord se, after the installation of new battery i was not able to operate the audio system and i bought preused vehicle and the dealership is also closed and i do not have the 6 digit code to open the system and i could not find it along with the book-let. Any suggestions to resolve the issue.
  • vectra 1999 Mar 07, 2009
    i did what u to it was on 10_ _ _ _ i entert 1 234 and held down as
    then it just sed 9 safe then i though this must be good? or some thing
    then i held dowwn as again and it repeted same numbers 1234 agen
    and it sed 8 safe
    i did it to 7
    now it wont go down anymore its just stuck on 7 safe
  • Anonymous Apr 04, 2009
    i have 0 safe problem
  • Anonymous Apr 13, 2009
    hi, I have the same problem. I have been tried three times and none of those were successed, now my radio at 7 safe status. does someone has code originally from holden zavira and let me know, then I may try that code as I hear from friend of mind usually the code pretty much similar (as long as it has not altered).
    thanks
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
Posted on Jun 14, 2008
  • Antonio Diaz Mar 25, 2013
    thanks vanessa72 it really works
  • desmondwaino Apr 02, 2015
    But where can i get the code from
Vectra 1999,
wot u have to do is........
turn on the ignition turn the radio off, press down "AS" and hold and then turn on the radio! and it will come up the usual 7 SAFE
then keep "AS" pressed for another 2-3 seconds then let go. Then you have to LEAVE!!! key in ignition its ok to drive while doing this because i did but dont turn ignition off or take the key out or ull have to do it agen! i got told that it takes around 1hour to reset itself but myn took around10minutes, once it has reset the code option will appear.
DO NOT type in 1234 as that is not the code. Every radio etc has there own code so who ever braught the car brand new must have the codes, i found the codes on the back of my service booklet where the man i braught it from must have wrote them down to remember.
the reason its staying on 7 SAFE is because you have locked the radio because you have had more than 3 attempts so wot i have just told you to do that will unlock it but you must have the right number!
iive gvot a problem where i have unlocked my radio but now the cd player is saying SAFE when i try to use it so if any1 knows wot to do please tell me.
hope i helped any1 out. i have a vauxhall astra so hopefully ur vectra is more or less the same
Posted on Mar 19, 2009
  • 47 Answers
ENTER TE CODE USING THE 1 2 3 4 PRESET BUTTONS AND THEN PRESS THE AM-FM BUTTON IT SHOULD UNLOCK IF THE RIGHT CODE IS USED REMEMBER YOU ONLY HAVE THREE TRY
Posted on May 13, 2008
What is 7 safe
Posted on Feb 01, 2011
Turn ignition off then on hold as button dwn till beep sound let go then press number 1 twice ,number 2 twice ,number 3 twice then 4 twice it should now say 1111 ,hold dwn as button again til beep sound it will say testmode you can do this as many times as needed but radio will cut out after a few minutes and then u will have to repeat process, i dont hve the unlock code for my astra but found this wrks until u get one hope this helps ,if anyone knows who you ring maybe holden please leave input
Posted on Sep 05, 2011
    New Friend:
Can someone help me with a code also for a 520
serial number is bp8391x1727043
part number 92057951
Posted on Dec 09, 2015
    New Friend:
Can you help with the code for my Blaupunkt 520? From a Holden Astra 2005
BP2391 4 6463572
No. 92 057 951
Thanks,
Posted on Jul 15, 2015
    New Friend:
Can someone help me with my security code? Serial number BP839113641353
Posted on May 03, 2015
  • David Hurd
    David Hurd May 03, 2015
Can someone help me find the security code for my Blaupunkt 520?
No: 92057951
Type: U1E
SN: BP8389Y2710693
Posted on Dec 22, 2013
It always says safe 6 becausse i tried it once 0000 and it dosent work when i hold the as button how do i fix it help!!!!!!!!!! me asap
Posted on Jul 19, 2008
You code is 6195
Posted on Sep 17, 2010
What to do when my 520 Blaupunkt stereo is saying 7 safe help me please I've almost got no hair left please please
Do not enter anymore wrong codes or you will block the radio unit and will have to take it to an audio specialist to decode!
To get the Blaupunkt radio code sent to you just contact this link with the serial number of the radio and send £5: Car radio codes in Uxbridge London Gumtree
Apr 30, 2017 | Blaupunkt Car Audio & Video
Sound is only in mono how do i turn on sterio
you have to make sure you give correct stereo signal source to the stereo amp input, you can confirm this by changing your audio source to Left or Right. can your amp speaker out follow the sequence?
Feb 04, 2014 | Blaupunkt Car Audio & Video
Blaupunkt 520 unlock code
Try code 0453
If this code does NOT work then POST ANOTHER QUESTION quoting the MAKE of CAR plus ALL the numbers you have listed
The Code Entry Instructions are here
http://www.radio-code.co.uk/code-entry-help.php
Oct 15, 2009 | Car Audio & Video
Blaupankt 520 Car Stereo, for 2000 Holden Astra
take it apart and then use the serial code numbers any (4) also jumble
Apr 09, 2008 | Blaupunkt PCA250 Car Audio Amplifier
2000 Astra Blaupunkt Stereo
Leave SWITCHED ON...UNDISTURBED for a couple of hours
Apr 07, 2008 | Blaupunkt PCA250 Car Audio Amplifier
Car audio security code
pin is on the metal frame of radio on left or right side and on sticker starting with the letters BP- then your 4 dig pin also the radio code after the pin write it down to. swich your radio off press hold the AS button while holding AS button down press power button it will automaticaly ask for security code enter security code then radio code
Feb 22, 2008 | Blaupunkt PCA250 Car Audio Amplifier
Car Audio & Video Logo
12,554 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
