Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak rp 1200 - pilot is on, unit will not fire. 10-12 ohms in safety loop. 340 ma from generator with loop connected. 440ma with loop disconnected. Do I need to clean the generator/pilot orfice? If so, how do I get them out? Thanks
  • 990 Answers
If this is a MV heater you need 500MV to run the heater. 200 to start the pilot and 300 to open the main valve. If your dropping 100MV on the safty circut you will need 600 or better to fire the heater. I would clean all the connections on the safty circut. I will usually change the whole pilot assembly, but you can get away with just the pilot generator.
It's hard to say how to remove the pilot as their are a couple of different ones and the heater you have listed has none, but a hot surface ignitor instead. Also it runs on 110 or 220v stepted down to 24v for most of the safty circut.
Posted on Sep 05, 2010
Require millivoltage for gas valve on raypack pool heater
clean burn tube to pilot generator replace generator and make sure all wires tight
Apr 12, 2017 | RTO Pressure Switch 3902 Swimming Pool...
What can I do? Raypak 2100 R185A. Pilot is lit, but will not fire
check safety circuit or for loose wires to pressure switch or gas valve
May 14, 2014 | Raypak Free Hydraulic Lift Gate Delivery -...
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
The pilot light will light but not the burner. What might be the problem?
With the pilot light lit we know that your gas is ok and the pilot valve system works. To get the burner to light there are more things to go wrong . What must happen before the burner lights is a number of safety devices and other devices must work right. Here is a general list.
1. The temperature set point must be set higher than the water temperature.
2. There must be enough flow and possibly pressure.
3. There must be AC power.
4. The temperature safety switch must be closed.
5. Any remote switch must be on such as a switch in the timer.
If you have a schematic, a volt/ohm meter and some debugging experience you may be able to figure this out yourself. If not, I recommend you get a volt/ohm meter and call the Raypak technicalsupport at 800-947-2975 or 800-627-2975. They they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 27, 2011 | Raypak Versa Pool Heater Gas 55000 BTU...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
237 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
