Question about Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4
Took pump apert to replace bolt in middle body and lost the oil in side.need to refill before using
  • 30 Answers
Refill with mineral oil
Posted on Sep 05, 2010
Flotec 1 hp fp4032-10 Bracket position/bolt mounts
como poner en tiempo un cadila escalade 1999
Jul 10, 2013 | Cars & Trucks
2001 chevy silverado /170000 plus mileson when i went to pull out briskly the motor started tapping and lost constant oil pressure when it is idling the oil pressure goes down to almost zero and the op...
Sounds like your oil pump is "getting tired". If you plan on keeping it for any length of time, you're probably going to have to replace oil pump. To replace you'll need to drain oil, drop oil pan and you'll find oil pump and pick up tube and strainer bolted to lower part of engine. Unbolt, slide out holding oil pump shaft in engine, slide new pump/strainer and pickup in place, bolt in place, reinstall pan and refill with oil.
Feb 23, 2011 | 2001 Chevrolet Silverado 1500
How to assemble oil pump 1995 Heritage
Assembling an oil pump is not that difficult provided you do a few things to insure that it works correctly. Now, you didn't tell me if the engine was in the frame or out. The difference is that the oil pump drive shaft will already be in the engine and the assembly will be different than if the shaft is out of the engine.
The first thing is that you want to make sure the oil seal is in the pump body and that it's installed in the correct direction. The lip of the seal must face the feed side of the pump. If you look at the gears and the pump body, you'll see that two gears are "thicker" than the other two. Also, the area that these gears go into are the same, one side it deeper than the other in the pump body. The "thin" gears are the feed gears that pump oil into the engine and the "thick" gears are the scavenge gears that pump the oil out of the engine. Once you get the seal installed correctly. You can start putting the gears and drive keys in.
Start by pulling the drive shaft out the back side to the engine as far as possible and installing the inner oil pump gasket. "Stick" the gasket to the engine case with a thin coating of grease. Slide the driven scavenge gear on the shaft with the drive key installed in the keyway of the shaft. The driven gear is the gear with the keyway cut in it. Lubricate the drive shaft and slide the pump body up to the gears making sure you don't go too far and knock the key out of the shaft.
Now put the drive key for the feed side of the pump in the keyway of the shaft and install the feed side driven gear. Make sure the key does not come out of the keyway. Once you get this installed, put the idle feed gear in the pump body. Then install the snap ring on the pump end of the shaft.
Now, carefully slide the pump towards the engine while holding the oil pump drive gear in place in the cam chest. Slide the pump body up to the engine and loosely install the two short bolts in the pump body holding it to the engine. Turn the pump drive shaft and the drive gear so that the keyways are aligned and use a pair of needle nose pliers to insert the key. Then install the snap ring on that end of the shaft.
Then, "stick" the outer oil pump gasket on the outer face of the oil pump body and install the outer cover of the oil pump. Install the four bolts and snug them up to the cover. Now you are ready to tighten the bolts. You should have the pinion gear and oil pump drive gear removed from the pinion gear of the pinion shaft of the flywheel. This will allow you to turn the oil pump while you torque the bolts.
The oil pump bolts torque to 90-110 INCH pounds. Torque the bolts in a criss cross pattern while turning the drive gear in the cam chest with your fingers. If the pump tightens up at any point, you must loosen and reposition the pump slightly and start tightening the pump again. The goal is to get the pump to final torque and still be able to turn the pump freely. Freely is the key word here. Not herky-jerky turning or having to force the gear to turn.
Good Luck
Nov 10, 2010 | 2000 Harley Davidson FLSTC Heritage...
I had a bolt break off the engine shaft end and tookthe pump apart and replaced the bolt. How do you fill the pump back up with oil?
The pump housing usually has a plastic viewport about half way up on side of pump
Oil should come to middle of viewport
Use 20 or 30 weight non detergent oil > SAE20 SAE30
The engine uses 10-W-30 and should come about half way up dip stick
Oct 14, 2010 | Karcher 2500 PSI Pressure Washer
I need to replace oil pump on a 1988 ford bronco 2
Remove oil pan, making sure to drain oil first. Remove oil pump attaching bolts. Lift off oil pump and withdraw oil pump drive shaft.
INSTALLATION;
Prime the new oil pump by filling either the inlet or outlet port with engine oil. Rotate the pump shaft to distribute oil within the pump body. Insert oil pump drive shaft into block dwith the pointed end facing inward. The pointed end is closest to the pressed-on flange. Place oil pump into position with a new gasket and install attaching screws. Tighten the screws to 15-22 foot pounds of tourque. Clean and install the oil pump inlet tube and screen assembly with a new gasket. Tighten the bolts, then replace the oil pan.
Oil Pan;
Clean of any debris and replace gasket. Fit the oil pan bolts and tighten in two steps. Start from the rear/left hand side and tighten first, then tighten the bolt in the front/right side. Alternate from rear to front, working from back to front and front to back.
Oct 06, 2010 | 1988 Ford Bronco II
Where is the oil pump located in A 1993 ford thunderbird V6?
Inside the oil pan for the 2.3 and 5.0
  1. Disconnect the negative battery cable.
  2. Remove the oil pan.
  3. Remove the oil pump inlet tube and screen assembly.
  4. Unfasten the oil pump attaching bolts, then remove the oil pump gasket and the intermediate shaft.
To install:
  1. Prime the oil pump by filling the inlet and outlet ports with engine oil and rotating the shaft of pump to distribute it.
  2. Position the intermediate driveshaft into the distributor socket.
  3. Place a new gasket on the pump body and insert the intermediate driveshaft into the pump body.
  4. Install the pump and intermediate shaft as an assembly.
WARNING Do not force the pump if it does not seat readily. The driveshaft may be misaligned with the distributor shaft. To align, rotate the intermediate driveshaft into a new position.
  1. Install and tighten the oil pump attaching screws to:
    2.3L Engine: 12-15 ft. lbs. (16-20 Nm) 5.0L Engine: 22-32 ft. lbs. (30-43 Nm)
  2. Install the oil pan.
  3. Connect the negative battery cable, then start the engine and check for leaks.
On the 3.8...
The oil pump is mounted in the front cover assembly. Oil pan removal is necessary for pick-up tube/screen replacement or service.
  2. Raise and safely support the vehicle on jackstands.
  3. Drain the engine oil, then remove the oil filter.
  4. If necessary, remove the oil cooler.
  5. Unfasten the oil pump-to-front cover retaining bolts, then remove the pump from the front cover.
  6. Lift the two pump gears from their mounting pocket in the front cover.
  7. Clean all gasket mounting surfaces.
  8. Inspect the mounting pocket for wear. If excessive wear is present, complete timing cover assembly replacement is necessary.
  9. Inspect the cover/filter mounting gasket-to-timing cover surface for flatness. Place a straightedge across the flat and check the clearance with a feeler gauge. If the measured clearance exceeds 0.004 in. (0.10mm), replace the cover/filter mount. Replace the pump gears if wear is excessive.
To install:
  1. Lightly pack the gear pocket with petroleum jelly or coat all gear surfaces with Oil Conditioner D9AZ-19579-CA or equivalent, then install the the pump gears in the cover pocket. Make sure the petroleum jelly fills all voids between the gears and pockets.
WARNING Failure to properly coat the oil pump gears may result in failure of the pump to prime when the engine is started.
  1. Position the pump body O-ring seal and install the pump body to the front cover using alignment dowels on the front cover.
  2. Tighten the pump retaining bolts as follows
    1. For vehicles through 1993, tighten the M8 bolts to 18-22 ft. lbs. (25-30 Nm) and the M10 bolts to 30-40 ft. lbs. (40-55 Nm).
    2. For 1994-96 vehicles, tighten the four smaller bolts to 15-22 ft. lbs. (20-30 Nm) and the two larger retaining bolts to 6-11 ft. lbs. (8-15 Nm).
  3. If removed, install the engine oil cooler. Install the oil filter.
  4. Carefully lower the vehicle, then refill the engine crankcase with the correct type and amount of engine oil.
  5. Connect the negative battery cable, then start the engine and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 28, 2010 | Cars & Trucks
Need to remove external oil pump on a 95 ford tauras 3.8 v6.what all is involved doing this??
Oil Pump
Removal
  1. If necessary, remove oil bypass filter (oil filter).
  2. Remove oil pump and filter body to engine front cover retaining bolts and remove oil pump and filter body from engine front cover.
  3. Inspect oil pump body seal (6C639), oil pump and filter body and engine front cover for distortion and wear. Replace components as necessary.
Installation
  1. Position oil pump and filter body on engine front cover and install retaining bolts.
  2. Tighten the small engine front cover retaining bolts to 8-11 Nm (71-97 lb-in) . Tighten the large retaining bolts to 23-32 Nm (17-23 lb-in) .
  3. If removed, reinstall oil bypass filter (oil filter).
Dec 04, 2009 | 1995 Ford Taurus
Need to change oil in kawasaki ninja 250r.how many qts of oil does it take?
when you see the velly of the bike, you could find big hole cap which is oil filter. Take it off and replace it. Next to the cap, there is a bolt same size as the cap bolt which is oil tank cap bolt. When you screw the bolt, the oil will plow out. Let it plow untill done. Put the bolt back when it empty. Right side of the bike and middle of the foot fade, you could find a refill cap. Replace oil untill the oil fill up enough. Back side of foot fade, There is a oil check. Between full and poor would be fine.
Jun 13, 2009 | 2008 kawasaki Ninja 250R
Need to replace oil pump assembly
Remove the Oil Pump
1.
Step 1
Drive your Dodge Caravan up onto ramps or lifts so you have room to work as you pull out the oil pump. You could also use a jack, but make sure you brace the front wheels and engage the parking break so the car doesn't roll.
2.
Step 2
Disconnect the negative battery cable on your Dodge Caravan. Drain the engine oil and coolant into separate pans. Take the vehicle off the ramps or lifts. Remove the accessory drive belts and use an engine support tool to hold the weight of the engine.
3.
Step 3
Take out the right engine mount and bracket. Take off the timing belt cover and loosen the bolts on the timing belt tensioner. Remove both the tensioner and the timing belt then raise the vehicle back on the ramps or lifts.
4.
Step 4
Take out the oil pan assembly and remove the oil pump pick-up and the O-ring. Take the crankshaft damper out with a good puller. Use a puller to also draw the crankshaft sprocket from the front of the crankshaft.
5.
Step 5
Loosen the bolts on the oil pump and take them off. Remember where they were since you'll need to replace them later. Unscrew the relief valve.
Install the New Oil Pump
6.
Step 1
Clean all the parts to remove contaminants and debris then install the inner rotor. Make sure the chamfer faces the cast iron oil pump cover on the back. Torque the bolts to 105 in. lb.
7.
Step 2
Install the relief valve, followed by the spring, gasket and cover cap. The cover cap should be tightened to 40 ft. lb.
8.
Step 3
Fill the rotor cavity with clean engine oil to prime it then insert a new O-ring seal into the oil pump. Put Mopar Gasket Maker or equivalent anaerobic type gasket sealer on the flange of the oil pump body.
9.
Step 4
Align the oil pump rotor flats with the flats on the crankshaft and install the pump slowly, tightening the fasteners to 20 ft. lb. Add the new front oil seal and install it with the spring side facing the inside of the engine. Even it out with the engine cover.
10.
Step 5
Install the crankshaft sprocket with the special sprocket tool. Put on the oil pump pick-up tube and O-ring and torque the bolt to 20 ft. lb.
11.
Step 6
Insert the oil pan and install a new oil filter. Lower your vehicle then install the timing belt and covers and crankshaft damper with a tool specialized for the 2 mm by 1.75 by 150 mm bolt. Tighten the center bolt to 105 ft. lb.
12.
Step 7
Put on the accessory drive belts and adjust them to the right tension. Put on the engine mount and bracket then take out the engine support tool.
13.
Step 8
Add fresh oil to the engine and refill the cooling system. Use a 50/50 mixture of clean, ethylene glycol antifreeze and water in the cooling system. Start your engine and check for leaks.
May 21, 2009 | 2000 Dodge Caravan
Gearbox oil
On the side of the trans. you'll find 2 bolts that have 1/2" drive holes in them. A 1/2" drive ratchet head will fit in. On the upper bolt, you'll remove it and this is the hole that the oil will go into. Use a pump that screws to the top of the oil container which is available at any parts store. Pump the oil into trans. until it comes out of the bottom of the hole. Screw the plug back in and tighten.
Jun 22, 2008 | 1990 Nissan Pulsar
Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4 Logo
209 people viewed this question
Top Tsurumi Pump Plumbing Experts
Donni Steen
Tom Chichester
Are you a Tsurumi Pump Plumbing Expert? Answer questions, earn points and help others
