Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Is there a manual that shows how to reverse the door?
  • Frigidaire Master
  • 8,220 Answers
Affinity service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 04, 2010
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Aug 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Reverse door
Good morning friend, I appreciate your post!
I see you are trying to reverse the door for your Frigidaire top mount refrigerator, FFHT2117PS. I have successfully located your manual and it provides step by step instructions on how to reverse your doors. Hope this helps. -Matt
Frigidaire Manual Search Results
Jul 23, 2014 | Frigidaire FFHT2117PS 21 Cu. Ft. Top...
Can I reverse the door on a kenmore 253.6580250A
Remove doors starting from the top, reverse handles, and hinges starting from the bottom. Owners manual should show you how
Mar 04, 2014 | Kenmore Refrigerators
Replace drive belt on garage door opener craftsman. What do I take apart so I can replace belt
On page 10 and 11 of your owners manual it shows how to connect the belt to the trolley. You should be able to reverse these instructions.
Jun 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
What does the reversal kit consist of
As far as I know there isn't any "kit" needed to switch a door. It's just a matter of taking out a bunch of screws, reversing some door parts, and putting it all back together. Here's a link that shows how to do it for one model which is typical:
http://www.maytag.co.uk/Assets/U&C_MDE3706AGW.pdf
About all you need is a phillips-head driver and maybe a small putty knife to pry out the filler plugs from the holes you'll be using.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Door reverses about 1 foot from floor.
You can overridride by pushing and hold wall button. If the door goes down and reverses up about a foot from the floor it could be a force setting issue on the opener or an issue with the door. First, pull the handle on the opener and operate the door manually a few times to make sure it opens and closes freely. You should be able to open and close the door with one hand or there is a problem with the door. If you determine that the door is ok then look at the force setting knobs. They are located on the back and have numbers from 1-10. These should be set on about 4-5 for the upforce and the downforce. I hope this helps.
Feb 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replacing exterior door handle on a 1983 chev S-10
remove the door panel, disconnect the linkage from the outer handle and remove the 2 nuts holding it into the door. assembly is reverse of removal. You can pick up a Haynes manual at most any auto parts store that will give you step by step instructions and in most cases shows pictures. Hope this helps.
Jan 16, 2009 | 1983 Chevrolet S-10
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
357 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
