Question about Pass & Seymour #TM818WCC6 15A White Switch/Outlet
I have a 1595-SWTTRWCC4 switch. None of the wiring diagrams show the two black wires coming from the switch. I am using the switch to turn on a light above the sink and use the outlet for counter top appliances. Which wiring diagram should I use and what do I do with the two black wires that are attached to the switch?
  • 518 Answers
If the wires are coming out of the switch portion & not the outlet, 1 goes to power the other goes to that color wire that goes to your light. All you are doing with a switch is cutting one side of your power, putting switch in completes the circuit when it is turned on. Or breaks the circuit when it is turned off. The other wires, power in & back to light get wire nutted together.
Posted on Sep 04, 2010
To make things clearer.. i took this advice as best as i could understand it, but i will say this.
out of the two black wires coming out of the top of the switch, one will go to your black power wire, one will go in your HOT terminal. the black power wire will be attached only to one of those two wires coming out, i don't think it matters which one. this will cause the switch to operate whatever is powering those wires. the outlet part on the bottom will be powered by a separate set of wires .. the black goes to HOT the other wire goes on the other side. Hope this helps
Posted on Jun 02, 2013
I need a wiring diagram for two switches and one light
I f you intend to run one light with two switches you should opt for 3 way switches. the wiring diagram is usually inside the box if you by them boxed.
Mar 08, 2014 | Pass & Seymour / Legrand 1595-2SWT...
I need help with wire connections for power window switch on olds ciera front passenger door.what color wire connects it to master switch?
In the diagram, the brown wire is voltage for power windows. Goes hot when you turn on the key. Voltage comes from the power window circuit breaker. The black wires in the middle of diagram are ground. Use a testlite to check voltage on brown wire, key on. If the brown wire has voltage, to check the black wire for ground, use a testlite between brown wire and black wire. If lite comes on, you have voltage and ground.
Oct 15, 2011 | Cars & Trucks
I am wiring 12 Leviton dimmer switches to light up a series of 12 halogen under cabinet hockey puck lights. I am bring power to the first switch through a 14-2 wire and using a pigtail to conduct power to...
You cannot wire dimmers in series and expect circuit to operate.
Problem is not 100% clear. Add a comment and include more information.
1) You have 12 dimmers.
Each dimmer has 2 black wires and a green ground wire.
The 2 black wires tell electrician that the dimmer wires are reversible.
One black dimmer wire connects to Hot from breaker, and the other black wire connects to wire going to Load (halogen lights).
If power passes through each dimmer going to next dimmer, the circuit will not work.
2) Unknown what you are replacing. Are you replacing 12 switches with 12 dimmers? Or maybe replacing 1 switch with 12 dimmers.
Number and type of devices being replaced is not known. And wires to each of these dimmers is not known.
3) You have a single 14-2 wire going to all 14 dimmers? Or does each dimmer have a different 14-2 wire?
4) You want to wire dimmers in series? So you want power to flow through one dimmer and control next dimmer?
You cannot wire dimmers in this manner and expect circuit to operate.
You can wire ordinary switches in series, but not dimmers.
5) Typically dimmers and switches are wired in parallel.
The Hot wire connects to one wire on each dimmer.
Since your dimmer has 2 black wires, the hot connects to either black wire on dimmer.
Then a jumper wire is added to connection, and the jumper wire carries power to next dimmer, and so on.
In this manner, each dimmer receives 120V potential. And then wire going to load connects to other black wire on each dimmer.
Sep 10, 2011 | Leviton Electrical Supplies
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
I am replacing an existing switch/single outlet, the outlet was always live.the switch controlled a light. the existing sw was very old and only has connections on the back top.. The left had 2 white wires...
White wires under the silver screw...
The black wire under the black screw...
and the red wire under the brass screw...
If it does not work right then switch the red and black wires...
heatman101
Apr 20, 2011 | Pass & Seymour / Legrand 1595-2SWT...
Wiring comination 2 switch, with exisiting light to new bath fan
Hello anonymous,
I am concerned in so many ways... (USA NEC assumed):
FIRST concern:
(after the obvious BATHROOM/GFCI issue) is the
NATIONAL ELECTRIC CODE for wire/device capacity
INSIDE your existing ELECTRIC box...
The CODE requires wires to have space ... aside
from the fact that it is just plain dangerous to
pack wires densely and pack them together tightly...
Then... of course... You have said nothing about the wire gauge/ampacity... (again assuming 14 Gauge/15 Amp)... you will have to calculate the fill for each wire and check the Cubic Inches Plus your device against the ELECTRICAL BOX rated capacity...
That is just the BASICs of SAFETY.
Looking for a diagram of your
"1595" Legrand Pass & Seymour I have failed miserably.
I have found what YOUR switch looks like...
From an old electrician's standpoint...
If you have EACH device wire separately thru
their respective switches...
There should be NO POWER to operate the FAN.
The FACT that there is ... Is highly PROBLEMATICE.
It would seem that a PREVIOUS ELECTRICIAN
has switched the NEUTRAL side of your
old light circuit... Easy to prove with a VOLT TESTER.
I Recommend KLIEN NCVT (non-contact volt tester)
Klein Tools NCVT 1 Non Contact Voltage Tester Electrical Tools Amazon com
A SWITCHED NEUTRAL
poses an EXTREME hazard in a bathroom
(any water) location but is EASY to fix...
Rip it ALL apart and properly configure all the EXISTING WIRES...
Do it right... Be safe.
WHAT ARE TWO BLACK WIRES FOR COMING OUT OF PASS sEYMOUR 1595 SWT SWITCH FOR
Carnac the Magnificent
Apr 30, 2017 | Pass & Seymour / Legrand 1595-2SWT...
Please note that there are many ways to wire this device.
In general, this is how the Pass and Seymour Legrand 1595-2SWT device is usually wired:
There are 3 wires permanently attached to the device, black, red, and yellow. These wires are for switching _only_ and are in no way connected to the GFCI receptacle at the factory. The black is "common", which means that this is the wire that is connected to the incoming HOT (black) wire _from_ the circuit breaker (or source). When making this connection add an approx. 6 inch black pigtail to it. (more on this later.)
The red is connected to the black wire (switch leg) that goes to, pick one, let's say the existing lights. The yellow is then connected to the black wire (switch leg) that goes to the new exhaust fan.
The incoming white (neutral) wire that is in the same cable as the incoming HOT wire is connected to BOTH the white wire that goes to the existing light and the white wire that goes to the new exhaust fan. Again, when making this connection, add a 6 inch white pigtail to it.
The switches will now work.
Do you now see that to power up the GFCI receptacle all one needs to do is connect the (see above) 6 inch black pigtailed wire to the "HOT" (LINE) screw terminal and the 6 inch white pigtailed wire to the "WHITE" (LINE) screw terminal?
In this case the lower LOAD screw terminals on the device are _not_ used.
Mar 29, 2010 | Pass & Seymour / Legrand 1595-2SWT...
I need a wiring diagram for a double switch
The following applies to the Pass and Seymour Legrand 1595-2SWT combination two switches with GFCI receptacle device ONLY.
Sorry for the long post, but the manufacturer's wiring diagram for that device is very difficult to follow and I want to make sure that you understand what's what. A basic description of how the device works may help.
At the top of the switch is where one connects the incoming ( HOT circuit from the circuit breaker or source) (LINE) wires. The black is connected to the HOT terminal and the white is connected to the WHITE terminal. That powers up the GFCI receptacle.
On the bottom of the switch there are two (LOAD) terminals (HOT and WHITE). This is where one connects _any_and _all_ loads which are to be GFCI protected, including any downstream receptacle outlets that one may want to GFCI protect.
The thing to understand about GFCI's is that BOTH the hot and the "neutral" white wires for the load(s) _must_ be connected to the LOAD connection on the GFCI in order for it to function correctly. Think two wires IN from the (LINE), two wires out to the (LOAD).
Also, at the bottom of the switch should be 3 wires which are permanently attached to the device, black, red, and yellow. These wires are _not_ connected internally to anything related to the GFCI. The black wire is common and the red and yellow wires are the switch legs (pick one). In other words, individually, these wires function just like a regular switch. If one supplies 120 volts to the black (common) wire, when one switch is turned ON one or the other red or yellow wires (pick one, let's say the red wire) will be energized. When the other switch is turned ON the yellow wire will be energized. Understand that if the black (common) wire is not supplied with 120 volts you will _never_ power the red and/or yellow switch leg wires.
For equipment grounding, of course, the bare (or green) equipment grounding wires are all twisted together with 2 pigtails using a red or gray wire nut; one pigtail goes to the green screw on the switch and the other pigtail goes to the green screw on a metal box (if you have a metal box). There are other ways to do this, but that's the general idea.
OK, after all that, we're ready to wire the 1595-2SWT. Understand that there are many scenarios for wiring that device. I will describe the most common one.
The following assumes that you have only ONE circuit supplying 120 volts to the box. It also assumes that you have separate cables going to each switched load and that these loads are _NOT_ connected to any power source other than the one supplied by the switch itself. It's OK to have a 3-wire cable with ground (black, red, white, and bare) going to the loads. Additionally at this time we will also assume that there are no downstream receptacle(s).
After making all the equipment grounding connections;
LINE connections:
Connect the white wire from the incoming (LINE)120 volt cable from the breaker or source to the the white (LINE) terminal at the top of the switch. Connect the black wire from the incoming (LINE) (HOT) 120 volt cable to the HOT terminal at the top of the switch. You should now see that the wiring for GFCI receptacle outlet itself is accomplished.
LOAD connections:
The two white neutral wires in the box that are in the two outgoing cables that go to the loads are twisted together with a pigtail that is connected to the (LOAD) WHITE terminal at the bottom of the device. OPTIONALLY, if you have a 3-wire cable with ground (black, red, white, and bare), just connect the white wire to the (LOAD) White terminal at the bottom of the switch.
Here's where it gets tricky. Connect the black (common) wire that is permanently attached to the device to the (LOAD) HOT terminal at the bottom of the switch.
Do you see now that any loads connected to either the red or yellow wires will be switched _and_ GFCI protected? If not, please STOP what you are doing and post back here, or called a qualified electrician.
You may then connect the red wire to one of the switch legs and the yellow wire to the other switch leg.
Do you now also see that you can easily add a downstream receptacle to the deal by simply bringing a cable into the box from that downstream receptacle and connect it to the load side of the GFCI?
I hope this helps. BE SAFE and don't forget to turn OFF the circuit and test it to make sure it is OFF.
Feb 27, 2010 | Pass & Seymour / Legrand 1595-2SWT...
I wana put 04 harley hand controls on a 89 harley need wiring diagram
I think the wire colors changed sometime after 2000. If you still have the old controls, you may can make up your own wiring diagram. While you've got the switch housings open to put them on the handlebars, write down what color wires come off of what switch. Do the same with your old switches and your new switchs. If your horn button uses a red and a black wire on your old controls, and your new switch uses a red/white and black wire, then draw your diagram to match the red/white wire where the red wire went.
You're going to have to do a certain amount of this as you will not find a wiring diagram that shows an 89 model bike with 2004 handle bar wiring on it. Good Luck!
Jan 26, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Pass & Seymour #TM818WCC6 15A White Switch/Outlet Logo
539 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
