Question about Panasonic Health & Beauty
I have a Panasonic shaver, model ES8065. It needs a complete rebuild (battery,head,general tuneup). Please provide estimate and procedure. Reply to : jwieg@atlanticbb.net Thank you, James Wiegand
  • 5 Answers
SOURCE: Remington R 9170 shaver
http://www.remington-products.com/manuals/ib_mftitaniumu.pdf
In the PDF instructions it describes how to remove the batteries. The instructions fail to mention that there is a spit of yellow glue that is holding one of the batteries to the curcuit board with a death grip. Undoubtedly, you will have to use a knife, not in the glue, but on the skin of the battery. Pull on the teather wire, and slice the battery skin around the glue.
If after removing the batteries, and you are not thouroughly discusted with the manufacturer, then purchase a couple of AA Ni-cad batteries solder the positive of one battery to the negative of the other. then solder the free positive end to the red wire, and then the blue wire to the free negative end. Then try to remember how to reverse the process and put it back together, without leaving any parts out. ;-)
There is a risk of injury by overheating the battery when soldering. That should be avoidable if you remember how to drop solder. Just like its name, it involves having the wire securely held in place. Then hold solder iron over the wire/battery end. Then take some rosin-core solder and apply the solder to the hot tip. Then make sure the newly melted solder lands on the contact. Keep in place until it cools and holds the wire to the battery.
If you think this is better than writing to Remington complaining that they did not make it easier and use contacts, instead of solder, so we can simply pop in a new set of batteries. Or maybe look at other manufacturers, and see if they are any better.
Posted on Dec 28, 2008
SOURCE: Model 6550 electrc shaver how i can open case
I.fix problem
thanks
Posted on Oct 03, 2009
  • 4 Answers
SOURCE: My braun shaver does not run although the battery is good.
You can buy the motor drive unit here: http://www.electricshaverstore.com/get_item_7030621_braun-motor-drive-assembly-pulsonic-5671-790cc-959.htm but it needs to be calibrated to the circuit board according to everything I have read. Unfortunately, I do not know the procedure for the calibration.
Posted on Aug 20, 2010
walesarumi
  • 6993 Answers
SOURCE: Battery in Panasonic ES8183 wet and dry shaver
A 12 months old wet and dry shaver must have a defective battery after such long period of use.
The battery cell is weak and unable to hold charge.
You sure need a battery replacement. It's not necessary you get a Panasonic battery replacement as long as its the same size, shape and watt. You can get another battery from any electronics accessories store within your vicinity.
All you need do is disassemble the shaver, remove the old battery, use it as a sample for the replacement so that you can get the same battery size, shape etc..
To disassemble the shaver, first, take the shaver outside and use a can of air to clean the shaver. Repeat this at various stages of the dis-assembly, being careful not to lose any parts!
Remove the two screws at the bottom (the end that plugs in to the charger) of the shaver, and remove the bottom cover. Keep track of the two small washers, and a small flat plastic piece, about 10mm square that fits inside of the cover - these keep the unit waterproof.
Open the shaver head, and remove the blade assembly from the white plastic vibrating arm by pulling on it - it will pop off. Undo the two screws on either side of the arm, keeping track of the two small washers under the plate - these will tend to stay in place and stick to the metal plate or the plastic underneath the plate.
Press on the mechanism from the end you first opened, and notice a gap opening up where at the other end, just below the head latch button and hinge. Gently pry open this crack, and work the case apart. Keep the large O-ring that seals the case, and make a note of its orientation so that you can assemble it the same way.
This has been too easy, I know, so there is one headache. I have not figured out how to remove the sliding trimmer assembly. Because of this, I found it was necessary to pry the large black U-shaped plastic clamp from the vibrating arm at the same time you pull the innards out of the case
By now you should have access to the battery, and proceed for the battery replacement.
I hope you understand the above.
Good luck.
Posted on Mar 01, 2011
brector3
  • 1623 Answers
SOURCE: I need batteries for a
Panasonic doesn not make their shaver batteries available to consumers. However, you will find a compatible battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Posted on Apr 11, 2011
Why cant somebody answer the question about battery replacement on the model 8985 braun shaver?
shaveroutlet.com can provide the compatible battery type at the link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
shaveroutlet.com also has a video to help you with the procedure below
https://www.youtube.com/watch?v=D6jRpCnB8T4
Feb 11, 2015 | Braun 360° Complete 8985 Electric Shaver
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
Need battery replacement for Model ES882. If available what would be the approximate cost?
You can not buy the exact Panasonic battery for your shaver because Panasonic does not allow the sale of their specialized shaver batteries to consumers. However, you will find a compatible battery at shaveroutlet.com. See link below
Apr 13, 2011 | Panasonic Health & Beauty
I have a Panasonic ES8023 rechargeable razor and I want to replace the batteries in it. Where can I find replacement batteries?
When my ES8023 razor quit working, I decided to buy and try a Braun Series 3 razor that ultimately I was dissatisfied with. I favor the Panasonic's narrower head. Deciding to replace the Panasonic's batteries, they were very easily removed. Noting they seemed barely larger than AA batteries, I decided to try replacing the OEM Ni-Cd batteries with some NiMH batteries I had. My only real concern was whether the NiMH batteries would charge adequately from the ES8023 charger....they did, which was great news since Ni-Cd batteries are inferior to NiMH.
Adapting the shorter AA NiMH batteries to the shaver was as simple as laying a small hex nut (#10-32 size I think) upon the negative (upper) terminal in the shaver and then inserting the battery. This makes for a tight fit and provides contact for teh negative end of the battery. The positive nub of the battery makes contact to the shaver's positive terminal with no issues.
The original battery has a long pin extending from the positive tip that I think may be to provide a pin that extends through the shaver body for a charging cord to connect to. However, for the induction charger of the ES8023, I didn't think the pin would be needed, and it wasn't. With two NiMH batteries inserted as described and the shaver reassembled, I successfully charged the shaver overnight in the original charger. I believe NiMH batteries typically charge at a higher current draw than NiCd batteries do, so I do expect a longer charging cycle to be required, but I don't anticipate any issues.
Mar 07, 2011 | Panasonic Linear ES 8003 W Electric Shaver
Where can I find a replacement battery for a Panasonic ES4011 wet/dry shaver? I have looked everywhere. THANKS!
Panasonic does not sell the specialized batteries for their shavers. Your best bet would be to purchase one of the models that replaced it. I have included links to two models below. These are very similar to model ES4011 and use the same shaver head as your model
http://shaveroutlet.com/shavers/panasonic-es-rw30s-mens-wet-and-dry-shaver.html
http://shaveroutlet.com/shavers/panasonic-es4026-shaver-with-er416-nose-and-ear-hair-trimmer-p-699.html
Dec 15, 2010 | Panasonic Sonic-2 ES 4011 K Electric...
I need a battery for Panasonic E366 electric shaver. Anyone know where to get one?
Panasonic does not market these specialized batteries to be sold. You can only have the battery changed by the Panasonic service center in New York or San Francisco and it will cost you more to have it replaced than you paid for the shaver.
I suggest that you simply purchase the shaver that replaced this model. It uses the same foil and cutter as model ES366 and works the same way too. You will find it at shaveroutlet.com at the link below
http://shaveroutlet.com/shavers/panasonic-es-sa40-wet-dry-rechargeable-shaver.html
Dec 15, 2010 | Panasonic ES 366 S Electric Shaver
Replace batteries?
Panasonic uses a specialized battery inthir shavers that have prongs on the ends. These are used only in panasonic shvers. Panasonic does not and will not sell these batteries to the consumer. You can not replace the batteries in this model without sending the shaver to the authorized Panasonic repair center and it will cost you more to repair it than to buy a similar new model.
You may want to take a look at buying the updated version of your shaver. It uses the same foil and cutter and is VERY similar to yours. You wll find this model available at shaveroutlet.com. See link below.
http://shaveroutlet.com/shavers/foil-shavers/panasonic-es-sa40-wet-dry-rechargeable-shaver.html
Mar 20, 2010 | Panasonic ES 3042S
Panasonic 8077 shaver top fastener broken
This may sound nutty. Please don't laugh. It works: attach a rubber band from the top "broken" corner of the shaver to the underside. Yup. Lousy design. Are you done laughing yet?
Jan 28, 2009 | Panasonic ES 8077S Electric Shaver
Wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
May 30, 2007 | Panasonic ES 8077S Electric Shaver
Health & Beauty Logo
101 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
