Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Trying to replace broken upper rack adjustment arm . . .
Maytag dishwasher model MDB7601AWS: I need to install a new upper rack adjustment arm, as the front left roller on the old one broke. Is there an instruction sheet for installing this? The part I purchased did not come with any instructions for how to remove the old one and install the new. It looks like the plastic front cover of it has to be popped off somehow first, and I'm worried I'll break it by prying it off - I don't see any screws anywhere to loosen to remove it. Any help you can give will be appreciated.
  • 84 Answers
First off check to see if there is an endcap either the front or back of the track. if so remove the cap. check for end mount screws. if no screws the endcap opens up the route for popping the plastic cover off and exposing the screws.. see diagram(may not be exact model but it gives you an idea)
Posted on May 12, 2008
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
I have a Maytag MDW 7600AWS, Serial 16500063CG. I need a new upper rack. What is the cost? Does it come with the revolving arm?
Go to www.repairclinic.com and enter your model number.
Then search for your part for price and availability.
Nov 27, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
MDB7601AWS Maytag dishwasher
hi there,
go to www.whirlpooparts.ca and type in the model # under Repair Parts. it will show you the exploded view of the racks.
May 13, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
238 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
