Question about GE 24 in. GLD5500L Built-in Dishwasher
Wont start, No power, check cirket breaker: GOOD
Why wont frigidare affinity FAFW4011LWD start after the power went out? No lights come on, nothing.
Good Afternoon Friend,
I understand you are not receiving power to your Frigidaire Affinity washer, model# FAFW4011LWD. I also see that there was a power outage before the symptoms began. I suggest checking the fuses or circuit breaker to make sure that it has not been tripped. If the breaker has not been tripped, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire Washing Machines
Stopped working... Power suggestions?
I have a feeling that it's on the same circuit breaker.
I would suggest changing the breaker.
May 13, 2014 | Dometic RM2652 Refrigerator
Circut breaker sensor 1 and 2, also car wont start is problem in the security system
Cirket braker meens fuse you will have to replace first then try to start again.
Sep 11, 2013 | 1999 Mitsubishi Mirage
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Mashing wont run when i press start button, timer works but machine does not run
Hi, Check for power and check the breaker pannel. Check the basic things to look for.
Is the switch working... Good luck.
Jun 20, 2011 | Washing Machines
Dryer wont do anything. The circuit breaker is good, there is power at the outlet. when you close the door and set the timer and push the start button, it wont tumble or anything.
Check continuity through the start button WITH THE POWER OFF. A cheap ohm meter should show a reading through the switch when it is pressed. If that checks good, use the same meter to read from the switch through the start coil of the motor. You should see something around 4 to 10 ohms. No reading, then check the connectors that they are tight.
It is rare that the start coil goes bad because it is only used on start.
Dec 20, 2009 | Cell Phones
Machine wont start
REPLACE RELAY AND OVERLOAD ON COMPRESSOR
Apr 30, 2009 | Kenmore 57029 Side by Side Refrigerator
OWN AN '06 COMMANDER HEMI 5.7 CAR WONT START BUT HAS POWER TO ALL ELECTRICAL FEATURES MAKES CLICK BUT WON'T TURN OVER. TRIED TO REMOVE BREAKERS FOR STARTER AND STARTED UP AND DROVE BUT AFTER I STOPPED IT...
Check for power in and out of starter relay.Check power at starter (large terminal hot at all times, smaller one hot with key in start position.) Make sure battery terminals are clean ON inside where it matters and check connections on the other ends of battery wiring as well. Breaker should have continuity as well. If power is present at starter, likely starter has failed, but do not condemn till everything has been tested. I assume battery and charging system are in good condition?
Jan 12, 2009 | 2006 Jeep Commander
Ge dryer model# dvl223
This may sound silly but did you check (or have the means to check) for voltage at the outlet? The absolute bottom line is that if there is no power.......you get the rest.
Jul 27, 2008 | GE DBSR453EBWW Electric Dryer
GE 24 in. GLD5500L Built-in Dishwasher Logo
16 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
