Question about HP L1706 17" LCD Monitor
Removing the mounting stand
I want to remove the rear stand from the monitor completely from the body to fix the panel on a desktop. please help
You've probably worked it out by now, but I thought I'd post the answer anyway, for anybody who may come looking in the future......
If you look at the back of the monitor you'll see two screws which can be easily removed. What's not as obvious is the THIRD screw. To get at it you need to remove the top plastic section of the stand; I carefully inserted a blade screwdriver in the groove, then gently twisted it in a few places. There's no need to dismantle the rest of the base.
It was my 12 year-old son's eagle eyes which spotted that third screw. My contribution to this part of his MAME project was figuring out how to get at it.
I hope that helps someone.
Colin
Posted on Jul 30, 2008
This was P1551NG me off for ages until I stumbled accross your advice. Nice one. Thank you. Easy when you know how!
Posted on Jan 24, 2009
Colin2905 - I spent ages trying to work this one out, thank you for the sollution!!
Posted on Mar 27, 2010
Service manual repair
Remove first monitor from the stand then the rear panel cover may be removed by removing screws from the bottom then sliding out the rear cover from the front panel.
Dec 28, 2013 | ASUS VB195T 19 inch Monitor
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How to remove samsung E1920NX stand?
You may download your monitors manual from this LINK. See page 15 for monitor assembly.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 01, 2011 | Samsung SyncMaster 743B 17 inch LCD...
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
How do i change a brake light bulb on 2000 vw jetta?
Removing:
  • Switch off all electrical consumers, switch off ignition key and remove ignition key.
  • Remove rear luggage compartment side panel trim (left or right).
  • Remove 3 nuts, arrows, and remove housing.
  • Remove bulb holder.
Installing:
  • Install bulb holder.
  • Insert housing into body opening.
  • Tighten nuts.
  • Install applicable rear luggage compartment side panel trim.
Rear Light Bulb Holder Removing And Installing:
Removing:
  • Disconnect electrical connector.
  • Depress retainers, arrows, and remove bulb holder.
98971817.gif Installing:
  • Install in reverse order of removal.
And the Center Mounted Brake Lamp.
High mount Brake Light Removing And Installing:
The high mount brake light is installed in the rear shelf.
98971288.gif Removing:
  • Disconnect electrical connector from high mount brake light.
  • Remove rear shelf
  • Un-clip high-mount brake light from rear shelf, arrows.
NOTE: The bulb holder base plate contains soldered- in light emitting diodes (LEDs) that are not replaceable. In the event of LED malfunction, replace complete bulb holder.
Additional
Mar 13, 2010 | 2000 Volkswagen Beetle
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
How to open up the casing on this monitor.
It is not initially obvious how to access this insides of the monitor Unusually, access is only available through the front of the screen. The stand cannot be removed on this model. You need to pry a screw driver (or two) through the four holes located at the rear base of the monitor and remove the front panel surround. The LCD panel and all electronics can be lifted out after removing four screws.
Oct 03, 2006 | Tatung CLT-L50 15" Flat Panel LCD Monitor
HP L1706 17" LCD Monitor Logo
4,116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
