Question about Konica Minolta Magicolor 1600W Laser Printer
Konica Minolta printer Magicolor 1600w. Error message" memory" full when color printing. Not a problem when printing black and white.It is even more confusing,because it did manage to print a couple of color images. Printer is new and toner is full. I set to default and no luck. Help manual says press clear, if that doesn't work turn printer off for a few seconds, then back on. that worked once. Have tried turning off a dozen times and for different intervals to no avail. Thanks
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
SOURCE: to change opc drum in konica minolta
Search the web for the users guide. Instructions are under "replacing consumables"...dvw
Posted on Feb 24, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
I am printing pictures and they have a white line running through them, what can i do
Does the white line appear in all colors? Or is it limited to just one color? Try printing some full pages of each color (use a gray scale to save on toner, 50% shade should do). If the line appears in only one color, then replace that toner cartridge. If all three colors, then replace the drum.
Nov 25, 2014 | Konica Minolta Magicolor 1600W Printer
I am getting an error message of server memory full
Scanning issue ? or printing does machine print test ok and copy ok?
Apr 29, 2014 | Konica Minolta Magicolor 1600W Laser...
The black ink is NOT showing empty but it will not print
Firstly two things here assuming everything is fine with your printer.
Firstly have you changed the options in the document or picture youre trying to print? For example, if printing a document from Word, go to printing options and click advanced then print in 'black/white' rather than 'color'.
Secondly when you installed the ink cartridge in the printer, have you removed the plastic/paper sticker attached which protects the circuits and ink leakages?
good luck,
kc
Feb 23, 2011 | Konica Minolta Magicolor 1600W Printer
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Aug 05, 2009 | Konica Minolta Magicolor 4690MF...
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 1600W Laser Printer Logo
1,480 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
