Question about KitchenAid KEBC207 Electric Double Oven
I have a KitchenAid double oven with convection on the top and conventional on the bottom (model #KEBC207KBL0). When I set the temperature and preheat the top oven, the display shows the temperature rising but the oven temp never reaches the displayed temp. I hung two oven thermometers from the middle rack and when I preheat the oven, both thermometers agree that the oven is under heated by as much as 100 degrees. This started happening some time after we "self cleaned" the oven. Any suggestions?
  • service829 Sep 04, 2010
    Thanks for the quick reply, salde386. When the oven is on, yes, I do remember hearing a fan. Although, we mostly use the convection oven which runs a fan the whole time the oven is on. However, when we turn the oven off, I think some other fan usually keeps running for several minutes until the oven cools down. I will be sure to check this out the next time I (try to) use the oven. I am not looking forward to pulling the oven from the wall, but I found the installation instructions which will be helpful. Maybe I can figure out how to tighten the loose oven door handle while I am at it. Thanks again and I will check the fan screen and post the results of the test you suggested.
  • KitchenAid Master
  • 2,254 Answers
It will either be the sensor or the board,hopefully it's not the board,the part number for the sensor is 4455636 and subs to w10131825,the sensor is around 100 bucks,there should be a tech sheet on the machine most likely behind the touch pad on the top,it will tell you how to check the sensor with a meter,just unplug the sensor and read it out i think it's around 1100 ohms but check that on the tech sheet,if it's not the sensor most likely it will be the board part number 4453661 and that's around 300 buckseverything runs through this computer board but the sensor tells it how hot it is in the oven hopefully you have a bad sensor.let me know what you find,you'll most likely have to pull the oven to repair it but maybe just enough to get the top open,good luck
Posted on Sep 04, 2010
  • 4 more comments
  • Sal DeAngelo Sep 04, 2010
    one more thing,when the oven is on do you hear the fan come on,there's a fan that turns on to cool down theelectrical stuff,when you pull the oven check the fan,there's a screen that the air blows through,i've seen some of the screens blocked with lint and dirt and the air can't do it's job and the electrical gets damaged.when you self clean it's like 1000 degrees in the oven,if that fan can't blow through like it should you're gonna have problems,just a thing to look for while your in there.
  • Sal DeAngelo Sep 07, 2010
    i hope the info i gave you helps you out,if you need any help in the future let me know,something is wrong with this site,i've answered 20 people and nothing shows up saying anybody is writing back,i just happened to check to see if you answered and you did 3 days ago but like i said right now there's no way i can tell unless i go back and check all my answers to see if anybody else has replied back,good luck,make sure you shut the power down to the oven at the fuse panel before you touch it,there should be like 4 screws holding the oven in,there are pretty easy to pull,again good luck and let me know if you need any more help
  • service829 Sep 25, 2010
    Yes, I did reply to your first post but I cannot remember what I said in the reply/comment and I don't see it here. Anyway, I just today pulled the oven from the wall. I have not pulled it all the way out yet. It's pretty heavy and I need to find a way to support it.
    I exposed the circuit board and checked the resistence on both the upper and lower temp sensors. I tested the temp sensors with the sensor plugs pulled off the circuit board. The resistence was about 1100 ohms for each. Interesting ... when I plugged the temp sensors back into the circuit board, the resistence measured about 813 ohms. I wonder if that is expected behavior.
    One more thing I noticed. I ran some tests on the oven and refined the symptoms. I preset the temp and wait for the oven to preheat. When the oven "reaches" the preset temp, the display shows the preset temp and the oven beeps, but the oven is about 25 degrees too low. If I wait about 5 or 10 minutes, the oven reaches and stabilizes at the preset temp. However, if I open the door for about 10 seconds and then close the door, the oven steadily looses heat and does not appear to ever recover.
    Does this help or confuse the troubleshooting of this problem? Any suggestions?
    Thanks!
  • Sal DeAngelo Sep 25, 2010
    25 degrees is acceptable,all ovens will either run 25 higher or lower.you have a computer board that everything runs through,the sensor sounds like it's not the problem and i would change out the computer board,when you put the oven into self clean it gets like 1000 degrees in there and that's why i asked you about the fan,sounds like the board could have overheated when in self clean,also if it's heating then everything is working but the temp. is off or not responding when it should,if the sensor is good then i would go for the board
  • service829 Oct 17, 2010
    I found the problem. The documentation behind the keypad includes the schematic diagram and also instructions and specs on how to test other electrical components of the oven from right there at the keypad. I followed the instrunctions on how to test the heating elements and found that the convection element was reading infinite resistence. The convection element is accessible from inside the oven. When I pulled the element, I found that one of the contacts and part of one of the wires had completely burned off. I had to crimp a new (high temp) connector to the end of the burned wire and replaced the old, burned element with a new one (about $100). Tested and works OK.
  • Sal DeAngelo Oct 18, 2010
    that's great that you found the problem,it's hard to figure out the problem without being there,from the way it was discribed it sounded like it was heating but not maintaining the heat but as long as it's fixed that's all that counts,don't loose that tech sheet and you fixed it yourself
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
KitchenAid KEBC207 Electric Double Oven Logo
702 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
