Question about Generac Electrical Supplies
I have a brand new 17 KW LP generator that will not stay running when started unless I remove the air cleaner cover and move the choke plate by hand (which moves freely). When I change the position of the choke plate, the engine runs strong and at high RPM. The choke plate solenoid seems to be recieving a signal at start-up, but only flinches then remains in its position. email: wbartolo@newenglandenergy.com
  • 10,865 Answers
Since this generator is brand new, I recommend returning it if that is an option you have. IT is unacceptable to buy anything that requires service right off the bat. That said, it is possible that the carb. is out of adjustment, or that it is partially clogged. If you think it is partially clogged, get a can of starter fluid and squirt a little starter fluid into the air intake to keep it running smoothly for two minutes. This will unclog it. J.
Posted on Sep 05, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
My choke light stays on my 84 pontiac trans am. Why does this occurr and how can i fix this problem?
I bevieve that year is 305 or 350 with Throttle body injection so remove air cleaner cover start car allow to warm up then see if plate below main injector opens when engine is revved ..if it does then be sure it is partially open at idle .. check wiring underside of air cleaner / loose / heat damaged -----Or if Aftermarket air cleaner then unplugged wires from factory must be looped to create all ok signal .....The Throttle plate at base of unit or old style carb can wear creating unstable idle or choke light signal due to inconsistant air flow ..
Nov 11, 2014 | 1984 Pontiac Firebird
Yamaha ef1000 will start then push choke in and generator stops
clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
May 07, 2012 | Yamaha 1,000 Watt Portable Generator...
My 2 Yamaha ef2000is generators will only run anything in my camper that requires power (ac,tv, or microwave) unless the choke is on about a 1/4 of the way.
dirty carby jets. it is not receiving enough fuel thereby needing the choke. remove carby and clean jets thoroughly or simply try removing air filter & squirting carby cleaner into carby throat whilst revving engine several times, this sometimes works enough to solve problem.
Jun 30, 2011 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Will not start when cold if you ues starting fluid and get it running it will stay running until its shut off but if it sits and cools down for approx 1 hr it wont start the fuel valve was just replaced...
Sounds like the choke is not closing. Perhaps it has become detached from the manual throttle.
A simple test you can perform is to let it cool for an hour or more, remove the air filter and cover the air intake with your hand (making your hand a manual choke). If it starts right up, then the real choke is the problem.
There are two valves that you can see from the top of the carb. The one closest to the air cleaner is the choke. The other one is the throttle. Both valves operate through 90 degrees of rotation. The choke should close all of the way with the lever in the start position and be open all of the way with the lever in any other position.
Aug 02, 2010 | Northstar Generator 9 Hp, 5500 Watt,...
Briggs and Stratton propane gernerator will not run.
The engine is starved for fuel. Check fuel flow. Possibly a dirty fuel filter someplace in the line or the regulator has low flow.
You can verify this by putting an UNLIGHTED Bernz propane torch into the intake. If that improves it, then low fuel flow is the culprit.
Fuel filters for propane are very fine and can plug up easily. I am not sure where yours are, however I would check at the inout of the regulator for one there for sure.
Mar 31, 2010 | Briggs & Stratton Automatic Home Standby...
Won't start. on/off switch stuck, choke won't engage.
Mine did the same thing. Take off the cylinder cover as described above. Take off the screw holding the on/off switch. <br /> Bend the bottom of the silver metal shutoff band down where it rides against the back of the switch. Bend until switch turns on and off smoothly.<!-- from fixya rte -->
Oct 18, 2009 | Poulan PP4218AV 18" Chain Saw
Electrical Supplies Logo
142 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
Matt Olenzek
Matt Olenzek
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
