Question about Frigidaire Dishwashers
It is not cleaning dishes. I just took out all in bottom and cleaned really well. Loaded the dishwasher, started it and it sounds like it is working but the dishes are dry. There is water in the bottom and it does drain fine.
  • 3 more comments
  • spook14 Sep 04, 2010
    Dishes do not seem to even be wet.
    Since the dishes are not wet, could that mean that the arms are plugged? How do I take them out to clean.
    Dishes do not seem to even be wet. COuld that mean arms are plugged, and how do you remove them?
    Is this something that is easy to fix and not complicated. I am assuming I can order parts on line to replace that intake valve.
    I will try these solutions and hopefully I can get it to work. Thank you.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues. Then check the spray arms and try to clean its holes. Try & listen if it sounds like it is spraying the water around with enough pressure. For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump. Low water fills are a very common trouble maker with today's dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
  • Rylee Smith
    Rylee Smith Sep 04, 2010
    That means that the water inlet valve has gone bad, the
    water inlet valve is located behind the lower access panel on the left or
    right side of the Dishwasher. If the water inlet valve is bad you have to
    replace it, also check the main water line for clogs/obstructions. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Yes right, if the water inlet valve is fine then it means that the arms are plugged, you can click on this link on how to clean the spray arms. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Dishes in the top rack of my dishwasher are not getting clean. I had a handyman come, and he took out the spray arms and the mechanism at the bottom. The mechanism at the bottom was full of really thick...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 06, 2011 | LG 24" Built-In Dishwasher - Black
The glasses are really really cloudy. I cleaned the bottom and filled the jetdry area. Didn't fix the problem. What should I do now?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Apr 04, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Siemens dishwasher does not wsh the dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
eqrte
Jun 16, 2009 | Siemens 24 in. SL84A305UC Built-in...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Fisher and Paykel Dishwasher not getting dishes clean
Had the same problem and took out the inards and cleaned them. Also found that a lemon seed was blocking the drain channel - I used a piece of wire to snake it out. Seems like it needs periodic cleaning to keep it cleaning properly.
Nov 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
273 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
