Question about Sony Playstation 3 (PS3) Console
Playstation 3 Hi there, can someone help me to find on Playstation3 sparepart Damaged in transport dust protector lever on front top left hand side , mechanical part still works ok only need new dust cover . Many thanx Andy Melbourne, OZ
  • pilks88 May 12, 2008
    Yes , the one you can manually open and close to protect the input slots
  • SCOTT NELSON
    SCOTT NELSON May 11, 2010
    is it the face cover for the ps3?
  • 84 Answers
Dryer drum or rollers or bearings are squeaking on my Kenmore 970-C69042-00 clothes dryer. How do I best trouble-shoot and repair it?
Instructions
    • 1 Turn off the gas to a gas dryer or unplug an electric one. Move the dryer from its position at least 3 feet from the wall. This will give you room to work. Pulling the dryer out into an even more open space may make this easier.
    • 2 Push the putty knife in between the top and main body of the dryer on the front of the dryer. Slide the putty knife near the corner closest to you. Push the knife and pull up to release the pins that hold the top onto the body.
    • 3 Lift the top off the body using a screwdriver as a lever.
    • 4 Label the wires that are connected to the front of the dryer. Make note of which wire goes where. Unclip the wires from the clip that holds them, remove the wires and place them to the side. You will be reattaching these wires later. Be sure to mark them so that you can place them back in order later.
    • 5 Remove the screws that hold the fount of the dryer onto the rest of it. There should be four on most models.
    • 6 Pull the front towards you until the drum inside comes loose from its bearing. Slide the front panel up to reveal the pulleys at the bottom of the machine.
    • 7 Grab the idler pulley. It is the one in front of the motor. Move it to the right to disengage the belt. Remove the belt. Do not remove the belt that goes to the drum.
    • 8 Put on your gloves and slide the drum out of the dryer. Be sure to use hand protection as the edges may be sharp.
    • 9 Inspect the two rollers. If they appear damaged, or you find metal dust under them, your rollers need replacing.
    • 10 Remove the plastic clip on the right hand side if the right roller needs replacing. Remove the metal friction plate, metal brace and plastic clip on the left hand side if the left roller needs replacing.
    • 11 Put on the new rollers and reattach the parts you removed.
    • 12 Slide the drum back in and grab the idler pulley. Pull the pulley to the left until the belt is tight.
    • 13 Slide and screw the front into place and reattach the top.
Jan 15, 2013 | Kenmore Dryers
How do i change the toner on this copy machine?
Canon iR3300 copier /image runner is a best machine which is not needed any expert mechanic. Thanks to the manufacturer.If the toner in the cartridge was completed a message may be displayed on the screen that 'refill the toner'. Even though there will be a small quantuty of toner in the cartridge the message may be appear on the screen. Please don't bother about this mesaage. You may think the machine be damaged some where else. You might have handling the 'motor bike' or 'scooter' and you may experienced about the resrve . i.e. even though there is some petrol in the petrol tank of vehicle , the vihicle may stops to work. After filling of the petrol the vehile may run as usual. So , after the reserve of toner in the cop[ier the machine will stops to work. The you have to refill the toner cartridge with the fine quality toner of 1/2 kg or with 1kg. The cost of the toner may be Rs.500/- to Rs.650/- depending on the quality and the company and availability of the toner in the market. The toner must be compatible with the iR 3300 copier. After purchasing of the toner you must shufle the toner bag up and down nearly (100) times , so that the toner in the bag may thouroghly mixed and see that there will not be hard particles. Then remove the front cover gently and turn the side levers 1). left lever to left side and 2). right lever to down side. Then gently drag the toner cartridge of only 3/4 size. Please don't try to remove the toner cartridge completly out side of the machine. The costliest cartridge and not avialability of the new cartridge in the market may be break.At the front and top of the cartridge , there will be small lever attached to the cover of cartridge . Just hold the front ant and top of the cartridge with middle fingers and thumb fingers either side of the cartridge by both the hands and just press the levers out side towards you with the fore fingers of both the hands.. Then drag the cover only 3/4 of cover out side towards yourself. Make a small hole at the corner of the toner bag and pour the toner gently in to the cartridge. while pouring the toner in to the cartridge gently move the cartridge inside and out side , so that the toner may evenly spread in the cartridge. After pouring of hole toner , close the cover the cartridge by pressing the edge of the cover from out side and then press the cartridge in to the machine and there after turn the levers in to the original position and close the front cover.
Sep 24, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How do i thread a singer samba 1 correctly?
Thread on the reel pin, make sure the presser foot is up and the takeup lever at the top, take the thread to the left and through the top guide which is directly above the tension unit, take the thread down the right hand side and round the tension unit back up the left side to the take up lever, thread the takeup lever right to left, follow the guides all the way down to the needle and thread front to back.
Feb 27, 2010 | Sewing Machines
I need a threading diagram singer 329k sewing machine
Cotton omn the reel pin, take the thread from the right to the left and through the top cotton guide above the takeup lever, make sure the takeup lever is at the top and make sure the presser foot is up, take the thread down the right hand side, round the tension unit and back up the left hand side to the takeup lever, right to left through the takeup lever and then follow the guides all the way down to the needle and thread front to back, flat side of the needle must face back.
when you put the bobbin in, bobbin in your left hand and the thread must feed from the bottom of the bobbin, drop the bobbin, through the groove and lay the thread to the back.
Feb 12, 2010 | Singer Sewing Machines
When i turn on my playstation3 it wont turn on. It was workin
Your motherboard is damaged I would send it to be repaired.
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Dryer Drum belt replacement
first unplug unit..remove front panel 2 screws..under the bottom side of timer console there is 2 pin or scews on each side pull down firmly,or if screws untighen slowly...just let console hang..now you can see the 2 screws holding bottom of front panel door.remove theses 2 screws..now step up on stool remove the 3 screws across the front top of unit,,theses screws are facing the ceiling..now remove door switch connection.remove front ,,you about there if belt has pop remove,if you have to replace a damaged belt..take your right hand and go though machine unit you fell the idler wheel on right side back pull down and take belt of idler wheel and motor pully at the same time ,,if you cant get ittake you left hand and help from the left side..to put back just reverse,,always unplug..
Nov 04, 2008 | Whirlpool LTE5243D Top Load Stacked...
Playstation3 freezes up
this is similar to the red blinking lights on the xbox360...it seems your cell processor has overheated resulting in a cold solder joints or worse bridged solder involving the BGA array...I have had some success in fixing these albeit limited. SONY charges 150 plus state tax and sends you a refurbished unit. i can fix it for 55 shipped if interested
Jun 08, 2008 | Sony Playstation 3 (PS3) Console
My playstation 3 wont work
PS3 have been having trouble with most PS3 with 40 gb drive
you have a ONE YEAR WARANTEE, from date of purchase.
I suggest you call sony and request a shipping box to send back your PS3.
If heard alot of people having this trouble.
so CALL SONY!!
Jun 05, 2008 | Sony Playstation 3 (PS3) Console
New typewriter
On the right side of the typewriter, just beneath the carriage (as you are facing the typewriter) there is a small metal lever which you need to push back. It is the carriage lock used to hold the carriage in place when it's being transported in the case.
May 17, 2008 | Olivetti MS25 Typewriter
Sony Playstation 3 (PS3) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
