Question about Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range
I have a Kenmore, gas stove and the oven does not work. Can you suggest a repair? It's not self-cleaning.
  • Stoves Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 07, 2010
How do you turn off the self cleaning feature on kenmore gas stove 790.75660?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 06, 2010 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
HOW TO USE THE SELF CLEAN FUNCTION ON A KENMORE FREE STANDING GAS STOVE
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 23, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore Oven Problem I have a Kenmore 79012 Range. The burners and broiler work fine. The ignitor comes on in the oven, but it will not light. After a few minutes I can smell gas, but the ignitor is still...
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Jul 28, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
103 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
