SOURCE: dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
SOURCE: Unlocking the region code (code2) on a Panasonic DMR E85H to use region 4 DVD's.
hmmm..ok..do you have user manual, or do you need one?
SOURCE: Technika Pro 19" LCD TV/DVD LCD19DVDID-308
Select the DVD and type 9 7 3 5. This brings up a new menu. Select Region 0. OK.
SOURCE: Unlock region codes for portable dvd player - panasonic DVD LS80
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
SOURCE: Sharp DV-NC 200 (DVD) Panasonic TX-32LXD700A (TV)
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Unfortunately, if the Sharp DV-NC 20 was bought in Australia, it would not allow any mods/hacks to make it region free. Sorry. Additionally, even if the Sharp could be made to change regions, the Panasonic TX-32LXD700A uses a Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G. it is (again) hardware limited to the PAL Colour System (Region 2).
Good luck and Thank you for using FixYa. Happy Holidays.
Pls be informed that due to my current rank and rating, even a
Helpful would be detrimental to my status. Should this solution not address
your concern, it would be appreciated if you could just not rate it at
all. Cheers.
