Question about Haier XQBM22-C Top Load Washer
3 yr old portable washing machine - never been used will not drain water. what can I do
  • 176 Answers
Check the all hoses and watar pump
Posted on Sep 04, 2010
LG washer drains withour washing!!!!
Call LG customer service. The unit is probably still in warranty. If not contact a certified LG repair shop and have them come examine and if possible repair the machine.
Apr 09, 2015 | LG WFT1071TP Top Load Washer
Whirlpool washer model wfw9050xw00 This unit is 1 yr old and is stopping at various times during all of the cycles. Also the unit is buzzing a bit when it is using the pump for drainage. Some times we...
Only 1 yr old so I assume its a simple fault like partial blockage at pump. Remove filter bottom right of machine check and clean if needed . remember to use an old towel fist as this will contain around half pint of water assuming its drained 1stly , Always unplug machine from Electrics before any repairs, Good luck.
Jan 08, 2018 | Whirlpool duet Washing Machines
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Kenmore portable washing machine does not drain water properly
MOST KENMORE MORE WASHERS THE LID SWITCH DOES BAD FROM CLOSING ALL THE TIME,YOU CAN REMOVE THE LIP SWITCH WIRES(2 OF THEM) WIRE THEM TOGETHER AND YOU HAVE BY PASSED THE SWITCH AND YOUR DONE,LET ME KNOW HOW YOU DO-MIKE
Oct 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Haier XQBM22-C Top Load Washer Logo
66 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
