The Power Cable is usually supplied With The computer Cases PSU. newer Power-Supply-Units Usually Have 1 Or 2 SATA Power Cables Attached.
secondly, the motherboard will provide the SATAs Data Connections. ( Usually look Like a Black Plastic ) Letter L shape connector.
Solution. Upgrade Motherboard And Power-Supply-Unit.
Alternative, look on e-bay or similar site, to find a SATA/PCI Card. And A SATA Power Supply Cable.
Mike @ Compurepair.
Comments:
May 12, 2008
- Hi,
I don,t usually reply To Solutions that have already been Rated Poorly.
I will look up your motherboard Details And inform you if There are SATA Cable connections, On That Board.
Mike @ compurepair.
May 12, 2008
- Hi,
Having looked at your Motherboard Specs:- Intel GLAD845.
It does Not Support SATA. And Has 2 IDE Slots for IDE Hard-drive And DVD Rom Drives.
As suggested, you can work around This With Various Cables.
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
no video driver present since a reformat and can't seem to download, motherboard is a k8m400 for an...
(More)
no video driver present since a reformat and can't seem to download, motherboard is a k8m400 for an acer desktop
