Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
How can I fix shutter on EOS Rebel Ti 35 mm - Canon EOS Rebel Ti / 300V 35mm SLR Camera
  • Obertelli
    Obertelli Sep 04, 2010
    Sorry, it's impossible to answer this unless you state exactly what the shutter fault is.
3 Suggested Answers
  • 17 Answers
SOURCE: how to replace the door latch on a canon rebel eos ti
The cameras film door has a very small phillips head screw inside the battery doors hinge. Its a pain to take out & replace if you hands are shakey for this screw is so small. Also installing the replacement hinge would be a little harder to install tha removing the broken one.
I hope this information will help you. A camera shop should be able to do it for free if you maybe purchase some items there. Most shops which are very small and privately owned shops will do this for you
Posted on Mar 07, 2009
  • 149 Answers
SOURCE: Cannon 35mm EOS Rebel X S Shutter Problem
problem in shutter clean the shutter with white petrol dry it no need of lubrecant
Posted on Sep 11, 2009
Canon EOS Rebel GII With 35-80 Lens 35mm Film Camera shutter
In manual mode you should be able to change the shutter speed simply by turning the main dial (the thumbwheel located near the shutter release button).
Jun 28, 2012 | Canon EOS Rebel G-II 35mm SLR Camera
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
How do i turn my camera on or off. Canon EOS rebel X 35 mm
There is no on/off switch as such. Press the shutter button halfway to turn it on, and leave it alone and it will power off.
If you need a manual, you can download one from
http://butkus.org/chinon/canon/canon_eos_rebel-x_rebel-xs/canon_eos_rebel-x_rebel-xs.htm
Dec 24, 2010 | Canon EOS Rebel X 35mm SLR Camera
Canon rebel 2000 EOS pictures are cut off by 1/3
shutter problem, cut off is part not exposed,replace the shutterunit.
Mar 07, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
Canon EOS Rebel Ti
you mean the flash is not opening or coming out of its enclosure? if its not opening up, its stucked! try inserting a small plastic card into the flash compartment. a hook is holding the flash from coming up like a door lock. its near the shutter button side; if its up and not flashing take a look at the bulb, if theres a change in color its dead already. dead bulb can be checked by shooting on autmode (the green mode), dead bulb will gonna shoot but flash wont go, if the flash circuitry is bad it wont shoot no matter what.
Sep 03, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Pictures are not turning out REBEL Ti
If your film's ISO speed is relatively high (say, above ISO 200 or 400) and you're shooting in bright light, your camera's shutter/aperture won't be able to compensate for the light. In that case, using a slower film is the solution.
Aug 30, 2006 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
123 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
