Question about Altec Lansing 220 Computer Speakers
I have audio when I boot my computer but at no other time.
    Problem Solver:
  • 12 Answers
Good chance that your driver has acted up. You will need to uninstall the software for the audio card and then reinstall. Also, make sure your volume is up!
Posted on Sep 04, 2010
I downloaded a audio update and computer only shows blue screen
Sounds like you downloaded a file that is not compatible with your computer.
Press F8 just before it boots and select Safe Mode. Load with network support. In the search box type Restore point. Select a time when it worked and let it restore to an earlier time.
Apr 12, 2016 | Computers & Internet
Boot Error Shutting Down Sony NWD-B103F
Contact Sony Tech support via email. they should be able to help. it is free I think.
Jul 14, 2017 | Audio Players & Recorders
Can't get audio
try to update your audio drive
Nov 23, 2011 | Computers & Internet
How can I stop the volume from playing about every 20 to 30 seconds
im not sure what volume sounds you are hearing every 20/30 sec if they are not beeps
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Jun 21, 2011 | Computers & Internet
Has a sound card, reinstalled audio drivers, still no sound on my speakers, what else can i do?
The CD has "Diagnosticsand utilities" listed under the "Contents". You will have to boot from that CDdisk. To do this, power on your computer and tap the key to bring youto the "One time boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Select "Custom Tests" and run the audio test. If itworks using the diagnostics then your sound circuit is O.K. and you have a software problem or settings for your your audio device is not set-up properly.
Feb 22, 2011 | Dell Dimension 4700 PC Desktop
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Nov 18, 2009 | Gateway MX6440 (6585) PC Notebook
When 2 pcs boot at the same time on my GSC1464 switch, the one which the swtich's tune too work the video display like it should but the second limit the second computer (the one who wasn't selected) limit...
When a computer first boots up the video card send a request to the monitor to find on what resolutions the monitor supports. If the video does not get a response the card will default to very low resolutions. The only way to avoid this problem is to boot your computers one at time and keep the KVM on the computer until it fully boots to a desktop. This will allow the KVM to pass the monitor information to the computer.
Jun 29, 2009 | IOGear MiniView DVI KVMP Switch GCS1764...
No Audio output device is installed. Help reinstalling audio!
How long ago did the problem start? What operating system are you using?
If you are using Windows XP or Vista, one can do a System Restore. This works in the majority of cases that involve a software problem. If you are not familiar with System Restore, when the computer is booting up, press F* until the Windows Boot Screen appears. Choose Option 3 using the down arrow key on the keyboard, choosing Safe Mode. When the computer boots into Safe Mode, you will have the option of using System Restore.
If you are unsuccessful getting into Safe Mode, within Windows, click Start, the Run and type msconfig then press the button Sytem Restore.
May 19, 2009 | Toshiba Satellite U305-S5097 Notebook
Compaq Presario V2000 will not boot
The clicking noise from the hard disk indicats that you have a intermitten faulty disk and therefore the computer sometimes boots up. If you manage to get the computer to boot, I would advise you to backup or copy your data. If you can't get the computer to boot up then the hard drive is dead.
You do not need to buy a new computer, just buy a new hard drive, replace the faulty drive and install your Windows operating system, all your device drivers (eg. audio, video, LAN etc.) and all your programs. You or a friend have a few hours of work.
Nov 22, 2008 | Compaq Presario R3000 Notebook
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Altec Lansing 220 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
