Question about Lomo Supersampler 35mm Point and Shoot Camera
Lomo supersampler.... how do i get the film out?
Cant get the film out :(
  • cookiemo May 12, 2008
    thanks!!! :)
  • isabalien Dec 19, 2008
    I can't find the black buton that would release the film...
  • 84 Answers
On the camera you have a round loop on one side and a rectangle loop on the other side. next to the rectangle there is a narrow black slide button. press that button then open the camera. on the bottom where the film on the outside of the case is a black button that hold the film in place. slide that outward then remove the film.
Posted on May 12, 2008
Dâââ.... and how to REWIIIIIND the film???
Posted on Oct 01, 2008
Film not releasing on lomo instant. Any ideas on how to troubleshoot? this happened out of the box.
When you say not releasing, do you mean you are unable to rewind the film ? Have you pressed the rewind button ?
Dec 19, 2016 | Lomo Photography
I put the film in my camera backwards(with the tail of the film facing to the left) and i cant get it back out. when i tried pulling up on the rewinder thing part of it snapped off
If it was just the folding lever part of the rewinder which has broken off then you'll need to use a flat bladed screwdriver or the tip of a knife to lever up the rewind knob sufficiently to pull it up and open the camera.
If you've broken any more than that, then your camera is unrepairable. Spare parts are not available for your camera as it's only designed to last for six rolls of film. Even regular Lomo and Holga models are only intended to last for a maximum of twelve films.
Oct 02, 2010 | Lomo BRAND Fisheye 2 Camera UK seller...
My pictures and negatives have a white line going threw it .
It's scratch along the film and will have been caused by either faulty film (very unlikely but not impossible), or it has been scratched when running through the camera or processing machinery (sadly both very common).
Open the back of your camera and lay a section of scratched negative over the back, emulsion side down, just as it would have been when taking photos. Use the scratch to guide you to find any rough/sharp points especially across the masking frame (the 36mm x 24mm rectangular hole in the camera which determines the size of the image). If you find none, then take your negative along and ask ask at the photo lab you use whether they have had any problems. They'll almost certainly say "no" but will then quietly check and rectify their machinery if they find dirt or debris stuck in there. Frequently the fault is in their sleeving machine which cuts up the negatives into shorter lengths.
Unfortunately, it's a problem which is far more common these days. Most 35mm film cameras are old and poorly maintained, or are just overpriced and badly made plastic toy cameras like the entire Lomo range. In addition, many people get their films processed at local minilabs and as they're used less frequently now the standards of operation and maintenance have generally fallen. I find that if I use a postal processing service the large commercial labs have better maintained machinery. The downside is that the local minilab will often give a more personal service with respect to getting an accurately exposed print and the large commercial lab will not unless you pay for a premium service.
May 07, 2010 | Lomo graphy SuperSampler 35mm Film Camera
My super sampler wont click after i take my firs shot??
Pull the string to advance the film. As long as your film sprocket holes are lined up with the sprockets in the camera, your shutters will fire the next time you press the shutter button.
Dec 31, 2008 | Lomo Supersampler 35mm Point and Shoot...
I can't seem to click to take a photograph
Pulling the string doesn't take the picture, it advances the film. Press the button on top of the camera, you'll hear the shutters go, and then pull the string. Just make sure the film is taut when you load it, and that you're not yanking on the advance string too hard.
Flash on a supersampler
You can fire a flash independently of the camera while you're taking a photo, but no flashes can be "hooked up" to the camera itself.
Sep 25, 2008 | Lomo Supersampler 35mm Point and Shoot...
Rewinding film at end of roll
Try looking here:
http://www.lomography.com/about/faq/1637-how-do-i-rewind-and-remove-film-from-my-lomography-oktomat-camera
Sep 03, 2008 | Lomo Oktomat 35mm Film Camera
Lomo super sampler problems
Hi Vicky,
Yes I will be glad to have a look at your Lomo if you care to email me I will send you my contact details
SUPER8
Aug 19, 2008 | Photography
Super sampler How to get film out?
once you rewind the film line up the arrows on top of the winder then gently lift the winder to release the film canister
Jun 30, 2008 | Lomo Supersampler 35mm Point and Shoot...
My lomo will not advance the film after taking a shot
I fixed this a couple of ways with my own LCA.
One is to stick a piece of paper in between the 2 parts of the tape-up spool (the internal and external parts) to make them a tighter fit.
Also, I often fold the leader of the film back (very close to it's end), and push it inbetween the 2 parts of the take up spool, making sure one sprocket is securely placed into the small tooth/hook on the spool. So, the film is folded around the tooth and towards the back, on the inside of the spool.
Jan 08, 2008 | Lomo Kompakt Automat 35mm Point and Shoot...
Lomo Supersampler 35mm Point and Shoot Camera Logo
421 people viewed this question
Top Lomo Cameras Experts
Are you a Lomo Camera Expert? Answer questions, earn points and help others
