Question about Toshiba Satellite A55-S306 Notebook
Over heats and shuts down - Toshiba Satellite A55-S306 Notebook
    Problem Solver:
  • 12 Answers
When it is running, do you hear a fan? Sounds like the processor fan is not working. The fan might be connected.
Posted on Sep 04, 2010
My Kenmore Elite HE4 dryer keeps shutting off after a few minutes.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Jul 09, 2015 | Kenmore Elite HE4 Electric Dryer
Why does my 2003 Harley shuts down when hot?
check oil and coolant levels its over heating and designed to shut off to save engine
Aug 08, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
Jul 31, 2012 | Dryers
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
2006 tahoe with heated seats. when the seat is
The heating element in the seat may be failing, even thogh it heats the seat, the element could be causing the circut to spike upon power shut down. Relay takes mili-second to shut down after ignition kill and power feed comes direct from battery. Check amp. draw at switch of bad seat and good seat upon shut down. If bad seat higher that 5 amp difference element n/g. Also check for bad relay as they can short internal and cause problems if primary power cut before switch shut down.
Jan 30, 2010 | 2003 GMC Sierra 1500
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Heat Sink
Sounds like the power circuit on the motherboard could be faulty. Look for any leaking capacitor on the board, may be fixable by replacing the component. It's easier but more expensive to replace the system board.
Jan 16, 2008 | Toshiba Satellite A15-S157 Notebook
Toshiba Satellite A55-S306 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
