Question about Garden
Model no. 358.795800, hard to start & when it does won't run very long. If i give it full gas it dies.
  • 2,272 Answers
It sounds like the lines are hooked up correctly, otherwise you wouldn't be getting fuel flow when you prime it. It sounds like you may have an air leak in the line to your carbuerator and once the initial primer gas is used, it's not drawing a steady flow of gas to continue running the engine. check for a small leak or crack in the line. Remove the Muffler and Make Sure the Exhaust Port is Clear. If it is, then Try to Start the engine with the Muffler Off. If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required. Also check the gas line.There are 2 gas lines coming out of the tank. One is small and one is a little larger. There are 2 nipples on the carb, both small and 2 on the primer, one large and one small.The small line from the gas tank is the gas feed and the large one is the return. Since the primer has a large and small port, the return to the gas tank should go to the large port on the primer (this is also the "push" port on the primer). The small gas line should go to the carb "in" which the top port. The bottom port on the carb should go to the primer small port (this port on the carb is an outlet). With this configuration, the primer is pushing into the tank and sucking from the carb. The owner's manual says the primer is for removing air from the gas lines and carb, so maybe the primer is not removing gas from lines.Check out this also. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 04, 2010
Won't start, but after sitting a day or two It starts right up.
check fuel pressure could have clogged fuel filter or bad fuel pump.
Jun 11, 2013 | 1995 Geo Prizm
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Runs for about an hour then just dies and won't start.
run it with the gas cap loose the vent on it might be plugged
Sep 24, 2012 | Craftsman Garden
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
Runs at full throtle and then stops
sounds like you have a crank seal out of it, you ncan try to clean carb and check fuel lines etc, but usually when they rev high with out giving throttle means there is an air leak Good Luck 2StrokeJim
Nov 19, 2011 | Poulan 25CC Gas BlowerVac
Started homelite 16 in (the jd 3816 model- new plug and started on a small dose of raw gas--got it running but won`t open full thr ottle- this saw has had very little use- oh put in new j-8 plug but once...
Either that season's gas dried in the carburetor affecting it's operation or you are drawing air through a fuel seal somewhere. Both are common with this model. Sometimes will start from cold and run up to half speed until you take the choke off. Then it just dies from not drawing gas. Status proved if it revs up if sprayed with short blip of ether from 7" away at the moment it dies. Do not try to keep it running on ether more than a minute. Like pure gas, it'll burn up the engine or worst. Do not use ether if the air is not moving. Ether may collect and explode.
May 05, 2011 | Homelite ZR10926 16 Chain Saw
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Mar 10, 2010 | Garden
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
