Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Freezer is working, refrigerator side is not cooling
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
  • 9 Answers
SOURCE: my refrigerator is not cooling the freezer is working
please check the rear interior freezer wall to see if there is any ice built up.If yes,that means you have a defrost heater problem.The defrost system consists of 3 components,1)defrost timer,2)the actual heater(which is located right inside the evaporator coil compartment),and 3)a terminating stat(which shuts off the the heater before the heat cycle ends to prevent overheating).There are ways to test this with a volt and amp meter. So,if this is the case,and you need a temporary fix,and I do mean temporary,(3-5 days)you can turn off the fridge for 24 hours and leave just the freezer door open until the ice melts,OR unplug fridge,then remove the interior back panel of the freezer and melt the ice by pouring hot water over the iced up coils(CAUTION:DO NOT POKE IT WITH AN ICE PICK OR ANYTHING,YOU WILL MAKE A HOLE IN THE EVAPORATOR).after ice is melted,reassemble rear panel plug it in,and it will buy you a few days. In a refrigerator, all the cold is produced in the freezer section,then through a small hole in the dividing wall,a small percentage of cool air is blown into the fresh food section.When the coils do not defrost 3-4 times a day like they should,the air cannot pass thru them and no air will be delivered to the fresh food section. Now, if you don't see any traces of ice buildup,you may have the air exchange door in the wrong position.The air door is a little door that determines how much air is passing thru to the fresh food section.Most fridges have the selector with either numbers or letters.Example A-B-C-D-E OR 1-2-3-4-5.Now when this air door selector is in the "1" or "A" position it means the maximum amount of cold air is going to the fresh food section,which in your case,is where you want it to go. Anyway if this is the case with you, after you have made the adjustment,please wait 24 hours to take effect,it's a slow process. I hope these suggestions help you. I know I probably gave more info than you needed to know. Good luck
Posted on Aug 26, 2009
  • 148 Answers
SOURCE: Refrigerator side not cooling. Freezer side okay.
call that company server
Posted on Apr 05, 2010
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Refrigerator Side not working freezer working fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Refrigerator side not working. freezer side seems to be working.
heatman101
Dec 26, 2010 | Maytag MZD2766GES Side by Side...
The refrigerator side is not cooling. Freezer side works fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator side not cooling freezer sides is working i had the fan motor replaced but still fridge side not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
dygjdgh
Jul 14, 2010 | Samsung RS2534 Side by Side Refrigerator
Freezer working - refrigerator not cooling
heatman101
dtiurt7
Oct 27, 2009 | Maytag MZD2766GES Side by Side...
Not cooling but freezer works fine
heatman101
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
