I recently purchased a set of Kross Bazooka Gold speakers. The set includes a suboofer and two satellite speakers. The subwoofer is working but I can't figure out how to get the satellite speakers working. I thought they just plugged in to the audo output area of the subwoofer but it doesn't work. In addition the plugs on the satellite speakers are tipped with some sort of orange rubber plastic part, which I thought should be metal. I wonder if this orange material is some sort of sheath which needs to be removed. Any thoughts?
SOURCE: Left speaker doesnt work
I have the same exact problem. This is why I don't like speaker cables that are permanently attached to the speaker. Arg. Now I have to go through the hassle of returning these!
Posted on Oct 23, 2007
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
sergiomc1
SOURCE: Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Posted on May 09, 2009
SOURCE: I have a BA635 subwoofer but do not have the other
Wanna Sell you subwoofer....I have the speakers....
Lookin for the Subwoofer....
Posted on Jan 19, 2010
Good Morning. I've purchased kross bazooka thunder usb stereo speaker do I need to install a special driver or sound card and do you know what will work with windows xp. Thanks for your time.
If you have Win XP SP2 or higher you should be fine with just the USB speakers. When you plug them in the computer will tell you if it found the speakers and installed the driver for them. It will say equipment is installed and working or it will say equipment did not install properly if there is a problem.
Mar 08, 2011 | Audio Players & Recorders
My CHT-8 powers on but doesn't have sound.
Check your receiver's speaker set up menu and make sure suboofer output is set to ON.
Jan 20, 2011 | Velodyne CHT-8 Subwoofer
I have an MTX1000xd and two Bazooka RS104DV's what wiring config?
Parallel will give you higher output but if you're hooking up all 3 you better use some very thick wire.Are you hooking these up to amp(s)?Sounds like a fuse is going to blow eventually too.
Good luck bro'!
Jul 17, 2010 | Bazooka RS104 Car Subwoofer
Hello the bazooka power wont come on
So it is a powered tube, yes? Can't remember, does the Bazooka have a fuse on it? If it is powered, you blew the board.
Apr 07, 2010 | Bazooka BTA8200 Car Subwoofer
Onkyo 875 suboofer problem
decided to get a technician over.
Apr 22, 2008 | Televison & Video
Is the subwoofer got a power? If not then troubleshoot the input power maybe fuse damage.
if there is power, EXamine the connection from the woofer to the output of the source. check the jacket of the of termination.
Apr 22, 2008 | Onkyo TX-SR605 Receiver
2001 ford explorer sport trax
probably exposed wires are touching something or they werent spliced very good,id check every point wher the wires were spliced together
Mar 25, 2008 | Bazooka BTA10100 Car Subwoofer
What up with my subwoofer?
Sometimes the Bazooka tubes have an internal amp. I am not sure of this model but maybe you can Splice in directly to the Speaker Wire and bypass the AMP in the Tube if it has one
Feb 06, 2007 | Bazooka BT6014 Car Subwoofer
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
671 people viewed this question
 Grubhead
Grubhead
