Question about Epson Stylus® Photo R2400 InkJet Printer
Printer is on but cannot print
Hope you can help,my printer showed 4 ink out & my son was attempting to open the printer to see what was wrong.any way he closed it back & step by step we changed the inks.But at that time the two top buttons were blinking red.I pressed the2nd botton to get it started but nothing happened.I turned off restarted the greenlight came on for 2sec.& went off & the two top lights keep blinking up & down.
Need Help Bad.My email is pacphotoservices@yahoo.com
  • 84 Answers
If your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
Posted on May 12, 2008
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
SeeTroubleschooting and Routine Maintenace chapter in user's quite.see clean unable 51 to MFC-230C
Hello and Welcome to FixYa!
"Unable 51" is most likely a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your problem will be solved.
For any further help, you can take my valuable,professional help by taking my Service
Thank You for using FixYa
Mar 02, 2012 | Brother MFC-230c Printer
My HP Office Jet printer is about 10 years old. Just recently it has been printing only in shades of red. No other color except black works good? I have changed the cartridge twice and same thing, so...
Sir if your printer just prints red shades then it Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:(a) Unplug the printer (b) Manually slide the carriage over until you can get the ink cartridges out.(2) Remove the ink cartridges from the print head.(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.(4) Repeat this until there is no ink residue coming off on the cotton swab.(5) Once finished, allow to dry and replace the cartridges(6) Try to print something now
If that does not work then you have one of two possibilities:(1) One of the ink cartridges is defective and causing the error(2) If it's definitely not that, then the print head will need to be replaced.
I hope this solution helps you.Don't hesitate to let me know if you have some confusion.
Sir, Your Rating as Maximum Stars and Words of Appreciation will be esteemed.
Thank you for taking my service.
Concerned: Muhammad Uzair
Nov 01, 2011 | HP OfficeJet r40 InkJet Printer
I have an on screen message saying ink absorber is full and printer will not print
You can reset the counter for ink absorber using a software tool:
http://www.ziddu.com/download/2620692/IPtools.zip.html
Follow these steps:
1. Unplug power 2. Open door and hold power button
3. Connect power
4. Close door, then release power button
5. Open IPtool, choose your printer model from the dropdown box and then in Waste ink container section click Reset Main.
Although this will solve you problem temporarily I suggest you to send the printer in service for changing the absorber which is something like a sponge inside the printer. Otherwise at some time ink will leak out of your printer and your printings will we soiled with ink too.
Hope this helps. Alex
Sep 14, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Print output is coming out fuzzy.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
How do i clean the heads on my lexmark x4580 printer the black is not printing but the colour is ok and the cartridge is full of ink cheers
  • Hello,
  • Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
  • (1) Open the printer and wait for the carriage to slide over
  • (2) Remove the ink cartridges from the print head.
  • (3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head and the electronic contacts on each ink cartridge.
  • (4) Repeat this until there is no ink residue coming off on the cotton swab.
  • (5) Once finished, allow to dry and replace the cartridges
  • (6) Try to print something now
  • If that does not work then you have one of two possibilities:
  • (1) One of the ink cartridges is defective and causing the error
  • (2) If it's definitely not that, then the print head will need to be replaced.
  • Thanks
Mar 10, 2011 | Office Equipment & Supplies
The printer connects to the computer and pulls pages through fine, but the pages are coming out blank. I've replaced the ink and cleaned the nozzles but nothing will get it to print!
Hello.
I know you've cleaned the printheads, but try this method:
(2) Remove the color ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
If that does not work then the print head(s) may need to be replaced.
Hope this helps.
Oct 23, 2010 | Epson Stylus C66 InkJet Photo Printer
E 5 problem printera canon210
Hello, Anita.
E5 is usually referring to a cartridge problem.
First, clean the contacts:
Your cartridge could be faulty and need replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA® MP210 Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
MFC-215C printer not printing
Hi, I had the same problem and found the answer from one website. Heres how you can fix it
1) Open the cover
2) Remove the empty cartridge
3) Close the cover without putting in the new cartridge
4) Open the cover and install the new cartridge
5) Close the cover and restart the printer (press power save to shut down and press it again to turn it on
It should go into cleaning and when you check the Ink Status monitor, it will detect that the ink is full.:) Hope this helps, it worked for me
Apr 02, 2008 | Brother Multi-Function Center® MFC-215C...
Epson Stylus® Photo R2400 InkJet Printer Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
