Question about Singer Sewing Machines
SIs there a certain measurement for the needle to the hook, when timing the Singer drop in bobbin electonic sewing machines? Or is it just timed for the furthest right that the needle will swing, when in Ziz-Zag mode? Well, I adjusted it in the center last evening, and it misses stitches on the left, so I'll just open it up again, and adjust the needle hook to the extreme right possition. That should take care of all my missed stitches.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
I'm assuming you're referring to the height of the needle at its highest point, and YES, there is a specification for it. It is possible for the needle height to go "off," and when it does, it won't pick up the thread. That is one of the two causes for the thread not being picked up -- the other is the hook timing.
The easiest way to address this is to purchase the service manual for your machine -- it will tell you how high the needle is supposed to be and how to adjust it. Sewing Parts Online sells service manuals, and if they don't have it they can order it for you -- generally takes two weeks.
Zigzag stitching has nothing to do with it, by the way--leave that part alone.
Posted on Jul 07, 2017
SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Posted on Oct 30, 2007
  • 749 Answers
SOURCE: upside down stitching
try adjusting the thread tension control! a loose setting would cause the problem! try increasing tits tightness!
Posted on Nov 02, 2007
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 46 Answers
SOURCE: skipped stitches
Change the needle first and make sure it is inserted correctly. Use good thread i.e.: Guterman or Metler are some. If you are using a stretch material then put a stretch needle in the machine. If you do all this and it still skips then you may have a mechanical problem with the machine. The machine is "out of timing". Have a good tech. look at it. This happens quite frequently on "inexpensive" machines. Sorry.
Posted on Jul 28, 2009
WonderTech
  • 268 Answers
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
I hope this helps you.
Posted on Sep 15, 2009
Testimonial: "great advice!"
Singer 7256 hook timing off
Hi Sherri,
I'm not sure that's possible in this case. Unless we can get the measurements for this machine and the instruments needed to execute the adjustments you'd need, to set all the measurements it takes to make a sewing machine sew correctly and safely.
I have seen some master machine repair technicians do it by sight and feel. I would let the pros help me with this. Yelp is a great place to start for a honest and able repair shop is near you. Besides, any needed parts aren't sold on a end user level. May be as simple as using the correct needle for the machine.
Cheers,
Embroidery Services
San Diego, CA
Aug 02, 2016 | Singer 7256 Fashion Mate Sewing Machine
I have a singer 248 the needle broke and i replaced it now it seems the bobbin case is out of line as the needle is hitting it. My question is how do i reline the bobbin case??
When the needle broke, it could have caused the needle/hook timing to lose its timing. There are web sites and videos that show how to repair it yourself, or you may just want to take it in for service.
Feb 10, 2016 | Singer Sewing Machines
Cg590 timing
with needle in centre sewing position remove bobbin cover, needle plate, bobbin etc until you can see hook. turn balance wheel towards you until needle at lowest point then turn slowly until needle rises 3/16" hook should be behind needle just above the needle eye
Jan 02, 2014 | Singer CG590 Mechanical Sewing Machine
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
May 12, 2009 | Singer 3116 Simple
FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Mar 20, 2009 | Sewing Machines
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
