Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Unit will not shut off even though there is no demand for hot water
  • 20 Answers
Flow sensor switch is bad
Posted on Sep 16, 2010
Turbomax boiler fires up when no demand
It still has to heat the water for demand. It will cycle even when there is no demand.
Nov 17, 2017 | Water Heaters
Rinnai 24e
You need to check the water pressure and flow through the unit. It sounds like you dont have enough flow so it is shutting off.
Jan 29, 2014 | Water Heaters
Very hot water then it kicks off and I have to frequently reset
Even though the water is very hot do you run out quickly? If so the problem is the 'dip tube' if not it is most likely the upper thermostat.
May 07, 2010 | RELIANCE ELECTRIC WATER HEATER
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
When I run the hot water on my tankless LPG water heater the water will run hot for a few minutes and then shut down even though the hot water tap is still open. This means hot and cold water cycling...
There's a little device that is like a pressure switch that starts heating when is senses water flow. This is what happens when it starts to go bad. You will need to call out a professional and have it serviced and the part repaired or more probably, replaced.
Apr 09, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hot water problem
Someone has not sized the system correctly. The water heater will heat a certain GPM a certain temperature rise. Most of those "generalizations" from the manufacturers are referencing the lowest of all the flow requirements like 2 lavatories. The truth is, don't use other fixtures while showering or get a bigger system. Lots of information related to sizing the tankless system at http://www.mechanicalengineeronline.com/Mini_Sites/Tankless_Water_Heaters_Ebook/Tankless_Water_Heaters.htm Have a good one. PS:Properly sized On-Demand water heaters are actually really good. Be prepared for the day your water heater quits.
Mar 11, 2009 | Bosch & Tankless LP Hot Water Heater
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
My Rinnai R94 LSi stops sending hot water intermittently, resumes after a few minutes, no error message. Could it be water savers are reducing flow below the minimum necessary for the demand sensor? If so,...
II would think that the unit is going out on hil imit because there is not enough psi on the water coming in.Is this unit on well water or city?If it on well water you have run some cleaner in it every six months.L on the side of the heat or inside and there a toll free number to call talk to a tech.
Mar 07, 2009 | Water Heaters
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
49 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
