Question about Cycling
I need a chain diagram for a huffy trailmaster bicycle.
  • 58 Answers
SOURCE: rear wheel huffy bicycle
If you are talking about the plastic disk that attaches to your spokes, this is one of those parts that looks nice on the bike, but is not 100% necessary for safe operation of the bike. This disk is used to protect the chain from falling in-between the spokes and the gears.
If you need to reattach this, this should snap into the spokes without issue. If the clips that hold it are broken (as they often become) you can either learn to live with it, or take it to a bike shop to get the gear cassette removed and the part replaced. This is one of those cases where the tool you will need is more expensive than the part you will be replacing, so in my humble opinion, it is not worth the expense.
Hope this helps!
Posted on May 20, 2009
milten1
  • 1304 Answers
SOURCE: need chrome fenders for Huffy Bratz bicycle
http://www.huffybikes.com/Support/MissingPart.aspx
i know its silly and simple but when my son wanted to cusomize his bike we did so through this link
thay had ever paert we could think of huffy
hope it hlps you 2
Posted on Oct 19, 2009
plaztiksr4me
  • 154 Answers
SOURCE: I need a new rear tire for a Huffy Princess 16
ebay or amazon.com
Posted on Apr 09, 2010
  • 21 Answers
SOURCE: remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
Posted on May 14, 2010
Coachphil
  • 347 Answers
SOURCE: Chain Broke on a Huffy
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Posted on Nov 18, 2010
Huffy bike chain
Every Huffy has one. If yours is stiff, replace it. If its to short replace it. it its tool long replace it. Contact your local bike shop for assistance
Aug 11, 2014 | Huffy Cycling
How to fix my huffy rock it bicycle
Sounds like you may not tightening it down tight. should have about 1/2 play in it. If that dont do it you might look at the sprockets ( bent or missing teeth ) or may need a new chain. Hope that helps you. Good luck. Vern
Apr 30, 2014 | Huffy 20" Rock It Boys Bike, Black/Orange
Noisy rear wheel
The chain may be dry and needs to be lubricated. For lubrication, use a very light oil. Don't put grease as it will likely to attract dirt that will stick to the chain and the rear cog, which will worsen your problem.
Mar 13, 2011 | Huffy So Sweet Children's Bicycle
Brake system. how to install the brake system for huffy disney princess 16
The link below will take you through the brake assembly and how to use the brakes on a huffy princess bike. Go to page 30 and page 31. A diagram shows how the brake arm should be secured.
http://www.huffy.com/pdf/ownersmanuals/e0664c94-726b-49d6-8322-5e053dca5b0a.pdf
For more information on bicycles, bike safety or bicycle accessories, visit my website: Huffy Bikes
Dec 25, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
I need to know how to take a chain off without breaking it please
Pull the chain out slightly, away from the bicycle frame, at the bottom just behind the front cog wheel (attached to the pedals). While holding it out turn the pedals backwards and the chain will come off.
Sep 04, 2010 | Huffy BMX 20" Boy's Rock It Bike
Peddle just spin while bike riding bike it will not engage
The chain has come off. Refit it onto the cogs then you will have drive back.
Vote for me if this helps, thanks.
Jun 19, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
