This is a used TV i got a couple of days ago. when turned on, the volume is fine, but after a few minutes, the sound starts to be fuzzy and gradually goes off entirely. turning the TV off, letting it rest and turning it back on gets the sound back again, until it goes back out, so I suspect something may overheat in there. Am I right? What can be done to fix this problem? Thanks.
  • joe_chump May 12, 2008
    Thank you for your reply.
    The TV is a Daewoo DTQ-25S2FCV.
    Thanks!
  • 8,617 Answers
What is your model number of your set. sounds like the audio output IC has a thermal issue. But need the model number as some Sony standard TVs suffer from bad SBX modules. Post the model number and I will be able to help you properly.
Posted on May 12, 2008
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
Headphones keep going quiet.
I would return them and either get a new one from them or another manufacturer.
May 11, 2017 | Sennheiser RS 110 Consumer Headphones
Sanyo DP32649 works fine for a few minute, then sound goes off. turning the TV off for a moment & then back on restores the sound. But sometimes this will happen ever few minutes for the length of the...
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Jan 30, 2010 | Sanyo DP32649 31.5 in. TV
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
TV problems?
you could have a couple of problems here
sounds like your tuner is bad but it may be repairable
useually when you first turn your tv on its cold then heats up and more then likley solder joints start to open uafter warm up then if you shut your tv off for a few sec. turn on it may be okay till solder joint get hot then open up tou need your tv reaired or buy new one
Feb 17, 2008 | Televison & Video
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
Top Televison & Video Experts
