How do i install r401 line sets between condenser and air handler??
  • 306 Answers
Just use the same route that the other line sets were ran. Could you explain more to let me know a little more of the situation that you have.
Posted on Sep 04, 2010
  • rexdragon3 Sep 04, 2010
    I ALWAYS THOUGHT THAT LINE SETS CAME CHARGED WITH REFRIGERANT, IM NOT SURE THAT THE SET I JUST GOT ARE OR NOT. HOW CAN I TELL??
  • Ken Bledsoe Sep 06, 2010
    They are never pre charged. The Refrigerant comes in the Condensing unit. Any other ?'s just ask. Glad to help ken
I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The condenser was installed about 14 years ago and it's rated as a 10 SEER. Is there a problem of them operating...
The air 'handler' is nothing more than a type of fan turned by a motor.
The condenser however is a sealed, closed system with coolant that will need to be properly removed (EPA stuff). The condenser must be installed with care, recharged, then checked for leaks.
There is far more involved than replacing an air mover.
I do most of my repairs myself but sealed systems that must be charged is something I leave up to a pro.
Feb 14, 2015 | Goodman Heating & Cooling
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
How to evacuate system after installing air conditioner air handler?
The service valves are closed. Therfore once you solder to the stubs on the valves your gauges will read what is in the line set and evaporator coil. Pressure test to 150 and let sit. If determined your pressures held then evacuate with vacuum pump. You are evacuating the line set and evap coil only because your service valves are closed. THIS IS THE PROPER WAY TO DO THIS. Once evacuated to 500 microns, close manifold and open valves. You will then see your refrigerant charge and determine if more refrigerant is needed. Good Luck !!
Apr 10, 2017 | Heating & Cooling
We installe da T8011R Programmable Heat Pump Thermostat approximately 2 years ago and two weeks ago, the a/c unit began turning itself completely off (blank screen and all) several times a day and night...
If the screen is blanking out that means that the 24 volt power to the thermostat is being disrupted.
The most likely cause is a safety switch on the secondary condensate drain line. This means that the primary drain line is almost totally clogged and that the condensate backs up enough to trip the condensate overflow switch. When it shut the system down (blank thermostat) this allows time enough for the condensate to slowly drain out and the safety switch resets itself. Clean out the primary condensate drain line (hook a shop vacuum to the line where it terminates outside and sucks the gunk out of it), this should take care of the problem. If it does not then you may have to get an a/c technician to professionally blow the line out from the air handler and possibly clean the condensate tray out in the air handler.
Hope this helps.
One note: If the safety switch was properly installed then the system would shut off and never come back on until the drainage was corrected. Yours is obviously not installed properly.
Sep 10, 2011 | Honeywell Programmable Thermostat Heater
Our A/C unit when running, the drain water isn now backing up and leaking over the side in our basement. we've never had this problem before.
Hello, this usually indicates a clogged condensate line or cracked condensate pan. Try using a wet/dry by attaching one end of it to the otlet of the comdensate line, the suction pressure should dislodge the clog. If the line appears clean the the pan is cracked and will require a technician to come out and fix it.
Sep 06, 2011 | Goodman CKL36AR36 Air Conditioner
After installing an air handler for a heat pump system, the condensation started. the air handler sets in an outside, unconditioned space. it is well insulated,and all connections sealed with mastic. it is...
Hi, on the refrigerant lines that are now condensateing, all you can do with them that are exposed are to wrap them with the black insulation made for this and make sure you have your condensate line connected to the air handler at the evaporator coil with either pvc or hard copper. I have never had to put mastic on any joint in case I had to take it apart for some reason. It sounds as though you have all of the lines insulated and that. I am not sure what type of insulation you used on the pipe, but it takes the armour flex. It comes in 10' sections. That's about the only fix there is. It has to have a condensate line from the indoor coil to outside to let most of the water run off. You are not going to be able to get rid of all of the moisture, but if the heat-pump is set up correct as for the super heat and sub-cooling, it shouldn't condensate that much.If it gets bad, try the armour flex and the black pipe wrap. This should help you a lot. Keep me posted .
Sincerely,
Shastalaker7
A/C & Heating Contractor
Jul 02, 2010 | Heating & Cooling
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Need line set size for goodman ck-36-1a
If your running gas heat it's 5/8 3/8 tubing.If it's elec. heat it's 3/4 3/8 tubing. Etheirway 3/4 3/8 works for both. Use 6 wire for tstat from tstat to furnace or air handler, and you need is 2 wire from condensing unit [outside] to furnace or air handler or anything more than two.
Sep 26, 2008 | Goodman Heating & Cooling
Air handler will not run clogged up drain?
the air handler is in the attic or in a closet right? most likely the drain switch mentioned is in a pan located underneath the air handler, the switch is actuated when the condensation drain tube is clogged, ( when it cannot drain the water out of the pan), the float switch is actuated and the unit shuts off to prevent any more condensation, thus preventing overflow into your house/apt. the drain line can be sucked out by using a simple wet/dry vacuum of any kind from the end of the drain line ( usually a 3/4 inch PVC pipe located somewhere outside ).
Aug 14, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
